O T cable pulleys with built in leads
Paul Waddle
>I am interested in making a wood working machine that uses cable to keep the ends of a moving shaft advancing in a straight line. I was thinking of using cable pulleys.Straight pulleys do not work for 1/16-3/32" airplane cable. I need a source of cable pulleys that have a built in lead (partition)that will prevent one or two wraps of the cable separated and not wedging on itself as it winds and unwinds while moving. I can not find any satisfactory answer todate. This is old technogly used by industries as diverse as coal mining and woodcarving machinery .. Will you mechanical engrs,mechanics,tinkers help me? Much oblidged,pw
Re: O T cable pulleys with built in leads
Al Stokka - Cambridge, Iowa
>The previous generation of a garage door counterbalance system used just such a sheave to wrap the aircraft wire rope in tension from an overhead tension spring. I'd be willing to bet that used sheaves from a replaced door system could be had at zero or low cost from an overhead door service company.
Al
Paul Waddle
>Thanks Al,thats a place to start. I'm wondering if the shaft needs grooves cut axially and allow the pulley to move a fraction of an inch sideways while still being gripped to the shaft?Paul
GalenV in Iowa
>You are talking fine cable and one of the few places I have seen is on some old paper copy machines. Some drove conveyers inside for paper transport. Grooved cable drums not pulley.
You could probably make your own by wraping a drum with single strand wire and let the cable wrap in the grooves formed. Not sure of what you are looking for for travel to know compromise of diameter and turns.
If there is multiple groove pulleys for this fine cable you can make a loop system with two sets of pulley. The wrap comming off one grove feeds to the opposite groove on the second. The second multigrove pulley is canted so the wrap from it feeds the second groove of the first pulley. We used a two groove and three groove but for 3/16" cable.
We used this method for water treatment tow system, high tech name was "Sludge Sucker" believe it or not. Use a lot in the N & S Carolina states water plants. So blame them for name.
Galen
Curly Smith
>I think you're looking for Helical Beam Shaft Couplings and they're available from McMaster Carr at the link.
Re: Shaft couplings
GalenV in Iowa
>Curly
The couplings do have helical cuts but only a series of multiple as they do not run as a continuous helical path. They are cut clear through the body. They provide the flex for out of aligned shafts.
We used these for connction a servo motor to an indexing stepper switch for municipal softeners before the use of processor controls.
Would be good for connection of small shafting for his project maybe.
Galen
Paul Waddle
>Rep, you nailed it Galen,It is "cable drums" I'm refering to. I tried googling but no joy-just winches and hoists. I want to use 3/32" airplane cable. Ifn anyone knows a source,let me know. pw.
Dick Coers
>couldn't find exactly what you wanted, but this site has small rounded groove pulleys.
http://sdp-si.com/
Did you also post on CNCZone? Saw a post on there while trying to help.
Here's an older discussion based on the old Shopbots that used a cable drive.
Sorry, no REAL help though.
Re: McMaster Carr has small cable
GalenV in Iowa
>Yahoo or Google can fine a lot of suppliers for small aircraft cable. May even fine in hobby store and I know ACE hardware has some pretty small but not sure of sizes. Getting down to even picture wire size as it is in several sizes.
Galen
Robert Lemon - Sacramento CA
>Paul, I'm one of those guys you're looking for! I like to part out and in some cases reuse the parts. I just so happen to have a lot of that stuff laying around. Your post leaves a lot to the imagination. If you are trying to keep opposite side in parallel, it could be done with small chains and sprockets, rack gears with pinions on a shaft that goes across the parallel sides, timing belts and matching pulleys. Also, the cable system you are thinking of using. The cable system is used in various places on copiers. It is also used on old style drafting machines. I have parts of all of the above systems. I have 2 grooved idlers with ball bearings for the cable system. I think I also have take up drums. In my quick search I didn't find any of them.
Can you give us some specs on travel dimensions. A quick sketch with dimensions might help. Are you thinking of making a duplicating carver?
Bob
>Paul, I forgot to mention Small Parts Inc. http://www.smallparts.com/. All the items I mentioned are listed in their parts lists.
Paul Waddle
>I sent you an email,don't want to be too wordy here.pw
Carol - now back in Dubuque, IA
>If you deprive us of your wordiness, Paul, you have dealt a real loss to those of us with inquiring minds who may not be able to help but who are interested none the less. That is part and parcel of what makes this forum so great.
Please do not be so parsimonious. :-)
Paul Waddle
>Hey,my wife disagrees with you... he he. Oh well,just delete if I get too bad. I think I need pulleys with "x" grooves-like a level wind on a fishing reel. This will prevent cable jams ...Now where do I find such an animal. I'm thinking I've seen this type of pulley on a radio tuning button to move the inductors ... or is it the capacitors that change the frequency . Dang, is not so bad to get old,but its terrible to lose one's learning! pw
Dick Coers
>This has me a bit intrigued. Some more Google time has me headed in the direction of auto window regulators. I saw a pic on how to replace a regulator on a 2004 F150 and one pic seems to show a pulley like you are looking for. Couldn't tell for sure, and I'm at work, so, it's back to the grind and maybe you can stop at a salvage yard and see what they think.
