Tap drill size
Tap drill size
Tap drill size
Paul Waddle
>What is the formula for finding the tap drill size for a hole? I have long since forgotten it,but someting about diameter-number of threads/2. Thks pw.
Re: Tap drill size
Re: Tap drill size
Al Stokka - Cambridge, Iowa
>Paul,
The rule of thumb for tap drill size is:
fastener diameter minus fastener pitch
where: pitch = 1/number of threads per inch.
Al
Re: Tap drill size
Re: Tap drill size
Paul Waddle
>Thanks Al,does this give the 75% thread? I believe 75% thread gives 90% holding strength.
Re: Tap drill size
WhadHeSay?
>This is interesting but I feel like I am back in Latin class again. Could somebody explain this so I can understand. What minus what? 75% of what? Not unusual, buy I am lost.
Re: Tap drill size
Or, you could look it up…
Rod Peterson -- Ormond Beach
>…in the Drilling & Tapping Information Chart article right here on WoodCentral.
Rod
Re: Tap drill size
Re: Or, you could look it up�
paul waddle
>Thks,I appreciate the responses and the chart.pw
Re: Tap drill size
Re: Tap drill size
>Paul, from Wikipedia:
TD = MD - 1\N
where TD is the tap drill size, MD is the major diameter of the tap (e.g.,3/8 inch for a3/8"-16 tap), and N is the number of threads per inch (16 in the case of a3/8"-16 tap). For a 3/8"-16 tap, the above formula would produce 5⁄16 as a result, which is the correct tap drill diameter for a 3/8"-16 tap. The result produces a tap drill size that results in an approximate 75 percent thread.
Re: Tap drill size
look on the tap
Bill Tindall, E.TN
>All mine have the drill size stamped on the tap body
Re: Tap drill size
Re: WhadHeSay? *LINK*
>Barry,
The percentages are of the size of the hole to the full thread depth. Tap holes are typically given as 60% or 75% full thread depth.
If you drilled to 100%, the screw would slip into the hole. Drilling to 75% makes it easier to tap but provides less strength. If you drill the hole to 60%, the smaller hole will make it more difficult to tap but will hold better, supposedly providing around 90% of the potential holding power.
75% is especially recommended for shallow holes with fewer threads, where the depth of the hole is less than 1.5 times the hole diameter. All this is for metals such as mild steel.
You may find the link interesting.
BTW, a few months ago someone here recommended the tapping machine sold by Grisley. Based on that I bought one and I must say it is a wonderfully built and useful tool.
http://en.wikipedia.org/wiki/Tap_%26_die
Re: Tap drill size
Re: look on the tap
paul waddle
>I can't see it on small taps. I may change to metric,all one needs to do is subtract the pitch from the diameter to get the tap drill size-just like the formula. Ex: 6mm x1 screw 5mm is correct tap. BUT futher consideration ,I really don't use that many different sizes do You? pw
Re: Tap drill size
Re: No no.
>John,
"The percentages are of the size of the hole to the full thread depth. Tap holes are typically given as 60% or 75% full thread depth.
If you drilled to 100%, the screw would slip into the hole. Drilling to 75% makes it easier to tap but provides less strength. If you drill the hole to 60%, the smaller hole will make it more difficult to tap but will hold better, supposedly providing around 90% of the potential holding power. "
You have it a bit backwards (sideways?). The thread percentage refers to thread height as a percent of full thread. 100% is full thread (nearly pointed triangles in cross-section). 75% produces threads with a wider crest (and requires less power to turn the tap) and 60% produces trinagles slightly over half as tall as they are wide at the base.
Al
Re: Tap drill size
John in Calgary
>I flip open the lid of my tap and die set where I have strategically taped a copy of a table similar to the one Rod linked to that shows drill size vs. tap size.
Unfortunately, I never have the right size drill bit, so end up picking the next closest size anyways.
John
Re: Tap drill size
Re: No no.
>You're right, of course. I reviewed my tap-drill selector sheet before posting but copied the jist of the text from a "handy" web site. I'd like to blame my carelessness on my lexdysia!
I use a #7 or 13/64" drill for 1/4-20 threads, 75% on my chart. A bigger diameter drill, #4, gives the 60% thread. The formula gives .200 for 1/4-20.
Thanks for catching this so quickly.
