Air Filtration System -Long
GalenV
>My dust collector/air filtration system to this point is a 20" box fan and the fine alergen type furnace filter over the intake. This works if I keep it close to the lathe while sanding cause it plugs up in no time and then the air flow is reduced till it does no good. Not a good long term system.
I would like to get a unit I can hang in about a 350 square foot part of the basement shop. It seems hard to compare Jet, Powermatic, Craftsman, Delta, Grizzly, JDS and whatever else there is. Some are fixed speed and others three speed and rated somtimes without filter restriction so seem like that means little help.
Some it look like you can wash not only the electrostatic prefilter but the 3 bag filter as well. Some electrostatic or just paper prefilter are listed as disposal as well as the three bag filter. They all have a filter price tag like buying half a new overall unit. Not sure if washable is true if it is caked with fine dust, seems like you would just get a wet dust mat.
Not sure if the real low cfm are any better than home made and when larger if they run you out with noise.
From what I find on Wood Central search it is mostly the big dust collectors and cyclones.
Anyone have a simple way of picking a good air filtration unit for a small area and economical to keep filters up?
What ones to definitely stay away from?
Any commments would be helpful cause I am tired of trying to shop vac walls, floors, shelves, supplies and sure the shop vac is just resuspending it again.
Sorry for being windy, unless I put a filter over my mouth and call it good.
Galen
