new project-table
new project-table
new project-table
Bill Tindall, E.TN
>We eat on the front porch and watch the sun come up (in warmer weather, its snowing now). We need a coffee type table for this activity. Furniture design is not one of my talents but every now and then I have a fit of creativity and try something that works, now and then.
Shown is what will be the top of the table. What I found is that minor adjustments of one piece of this puzzle throws off the alignment of all the others, sometimes a lot!. My intention is to install these pieces into the frame with a tenon on the end of the puzzle pieces and a groove in the frame. So how to mark the tenons so in the end everything fits right?
I bradded the puzzle pieces to a piece of plywood which fixed their position as I wanted it. Then I laid the dry fitted frame onto the assembly as show. Next I will scribe the outline of the frame on the puzzle pieces, remove the frame and cut the tenons on the puzzle pieces which will ensure they will be aligned when I put it all together.
I expect I will gently curve the sides and ends of the frame and probably round its edges. Haven't decided on the legs. Anyone have ideas for legs?
Re: new project-table
How'd Ju Do Dat?
>Looks Great. How did you do the layout on the pieces in the flare.
How about some legs with similar curves.
>Nice. For legs, why don't you mimic the arcs of the pieces on either side of the center. Sort of tie the legs into the top. Use a suitable apron.
Agree with Barry and JL
mdclor
>Bill,
You are off to a great start. QSWO is my favorite wood so I am really looking forward to seeing the finished product. Mission style often uses curves to lighten the look, so I would probably make 2" square legs with the rays on all 4 sides and attach them to stretchers with M&T's, but that is just me being my normally not very creative self. :)
Merle
equipment needed
Bill Tindall, E.TN
>Roll of brown paper from Home Depot, Lee Valley curve making bows, soft pencil, large french curves, large tee square, and most important a long eraser(which was a lot shorter after I gave up trying to improve it). By trial and error(more of the latter) I kept drawing till it looked ok. Then I smoothed the lines with the Lee Valley curves.
after cutting 1/2 the pieces out with band saw I resawed them to book match the remaining half. Fitting after band sawing was very tedius. A tiny change in one piece telegraphed to the orientation of all the others. Eventually I gave up and said that is good enough.
I like your leg idea
Re: equipment needed
>Bill, I have at least two thoughts on the base. With a pedestal base you could make three "feet" with curves matching the ones in the top. I like three feet for this because they almost always sit firmly. Four feet might be tippy if you move the table around and the floor is not level. Thinking deck type floor here. (in this case the curved pieces would be horizontal)
Another thought is to make a typical apron frame and use four legs at the corners that curve out from under the top. By recessing the apron, the feet could be right at the corners. (the curves are vertical here.)
