water based urethane
andrew nistock
>Hi All ,
I would like to use "Zip-Guard" water based urethane on an oak bookcase. Tested it on a small area and it raises the grain so that it is the roughness of about 80grit sandpaper. Is there anything I can apply as a base coat to lessen this effect. The MC of the lumber is about 8% and it is fine snanded to 320 smoothness. Thanks, Andy
Re: water based urethane
Water based finish
Lee Schierer - McKean, PA
>If your oak is not stained, apply the first coat and resand. The second coat shold hnot raise as much. Many water based finishes have this result.
Some aren't nearly as bad. Try Varathane Diamond Floor finish (only available in gallons) or MinWax Polyacrylic finish for less grain raising.
Lee
Jay St. Peter - Southern, MD
>Wipe water on to the piece with a damp cloth. Wait until dry, then lightly sand to your final grit. This lessens the effect, unless you sand too much. Just enough to knock the rough edge off. You'll still get some parts that need a little touch up after the first coat.
steve mackay
>ESPECIALLY oak ! You are'nt kidd'n. I started wiping it down with a damp cloth like the dude on Holmes on Homes before I start woorking it. Opening the pores before any finnishing seems to "tone it down" a bit. Actually a lot. I get away with one sanding after three coats then three more. But then, things dry differently in my house.
Fred Davis
>Andrew,
the others have outlined the steps necssary to use water based urethane and you can see readily see the additional work involved in getting a finish you can live with.
Given the extra work , why do you think it is a better way to go over the traditional , tried and true ,solvent based finish spectrum of Lacquer, Shellac and Varnish ?
Less work, better looking, etc.
FredD
John Parker
>I use a seal coat of dewaxed shellac. The shellac will raise the grain slightly. A light sanding, followed by the finish coats works for me.
andrew nistock
>Fred,
I guess the main reason I wanted to try the water based is that I am not really set up yet to use the ones you mentioned and was looking for a product that didn't have the odors. I have done a few projects over the years and most always used "Velvit" oil followed by a good grade furniture wax. This project is for a customer that doesn't want that type of an oil finish and I was looking for something that would be fairly easy to apply with good results. Thanks for the info. Andy
Fred Davis
>Sounds like John's approach with a seal coat of dewaxed shellac would be the way to go and you get the benefit of the warmness in appearence that shellac gives.
It is important to make sure that the Shellac is dewaxed or the water base will skate around on it.
Sand the Shellac with 220 garnet "A" weight paper.
FredD
andrew nistock
>thanks all, will try your suggestions and let you know what works best for me. Andy
