Low voltage wiring question
Nat Robison
>I just replaced my garage door opener and I ran all the wiring for the wall unit and safety sensors without attaching them to the framing.....everything worked fine.
While stapling up the wire for the wall unit, I damaged it and had to replace that piece of wire. I think 20 ga. came with the system and I ended up using 18 ga. since that's what HD had at the time.
Now, the remotes work fine but the wall unit is not getting any power and therefore isn't functional. As near as I can tell, there's no kinks/breaks/damage on the wall unit's wire.
Does the gauge of the wire affect its function?? Any other ideas?
Re: Low voltage wiring question
Dave Anderson (PacNW)
>No problem going with one wire size larger. You have one of 5 problems, 1) bad switch, 2) new wire has a break inside the insulation, check each conductor with an Ohm meter, 3) look for a fuse in the wiring diagram, 4) bad relay, 5) bad connection (most likley)
Good Luck
Most likely
Lee Schierer - McKean, PA
>Most likey you slipped on one of the staples and shorted or cut the wire.
Lee
>Disconnect all wires from both ends and check across them with an ohm meter for a short. If no short, get a long test wire and check each from one end to the other to see if one is open (not conducting).
If the wires are good, check for voltage at the power supply. If none, a previous short may have knocked it out.
So it's possible that I blew out the wall unit??
Nat Robison
Re: So it's possible that I blew out the wall unit
>I don't know how these circuits are constructed, but it is possible. It is certainly one of the debugging steps I would do to find and fix the problem.
Once I blew out an internal fuse on a similar low-voltage control circuit on a heat pump with a momentary short. I had do disassemble half of the heat pump to even discover and replace the fuse. I'd far rather spend a few hours debugging and fixing than pay some service guy to do the same thing.
waroland
>If you don't find that there is a short with the wires disconnected just twist one end of the wires together and measure the other end for a short. This will tell you if the wires are good from end to end.
Re: Highly unlikely
Al Stokka - Cambridge, Iowa
>Nat,
The wall unit is nothing more than a simple momentary-contact switch. In fact, you can replace it with a 98� ($1.57 with tax) doorbell button (switch). It's not likely that you blew the wall unit but, if you can take it apart and check the contacts for charring then youe mind will be at ease.
Al
Re: Highly unlikely
del schisler
>like al said it is just a door bell switch use the ohm meter and put the probs on the 2 wires and push button that will tell you if switch is working You can't blow the contacts out with that small amount of voltage Plus not that much amprage eather It is fused Probly blowed out a fuse Their are fuse's in the unit I have seen a couple of these Look for a blowed out fuse check for a dead short across the fuse If you don't get this The fuse is open If it is open you are measursing some of the circut with fuse open My guess
Not necessarily
Bill Howatt
>I have a Sears opener about 10 yrs old whose wall unit contains a circuit board and some components including at least one integrated circuit.
Bill
Simplest way to check
Tim Greif - West of Chicago
>I believe you have a broken wire. The easiest way to check is remove the wall unit from the wall and hook it up directly to the opener terminals with a short length of some light gage wire like bell wire. If it works, you have a broken wire in the run between the opener and the wall unit.
This is not likely just a simple doorbell switch. New generation openers are digital. The wall unit that can independently open the door, turn on the light and/or set itself to security mode on just the two wires uses a digital signal format from the wall unit to the opener. Yes, you can just short the two opener terminals with a doorbell switch and it will work, but the other features require the smart wall unit's internal circuit. Bill has it right.
If the wall unit doesn't work hooked directly to the opener terminals with the test wire described above, I believe ou have puked the wall unit. The internal nuclear phenobulator is probably cross fused :-)
Good luck
UPDATE
Nat Robison
>As I should have mentioned when I posted originally, this is a wall unit with a circuit board......it's read out air temp, time, etc.
Anyway, I cut the bell wire about a foot from the opener itself and hooked it up.....I have power to it and it doesn't appear to be blown out.
I guess that the small gauge of the bell wire is very easy to damage and not be apparent to the eye.
Off to HD for another 30' of the wire and I'll be extra careful when putting it up. Thanks for all the suggestions.
