Urethane/polyurethane?
wilbur
>I never understood the difference between the two, if any. I see cans of finish with one or the other on the label. Can someone enlighten me? Thanks!
Re: Urethane/polyurethane?
>They are the same thing - even if they are incorrectly labeled. Urethane more appropriately refers to a urethane linkage (NHCO). Polyurethane just means many urethane linkages.
Spelling
Urethane/polyurethane- no difference
Bill Tindall, E.TN
>As far as looking at a can of varnish either label just means that a "urethane" chemical species was used in the formulation. Now days this labeling tells you nothing useful about the product.
A can of varnish consists of a mixture of a solvent and the stuff left behind after the solvent evaporates, sometimes referred to as the "film former" . In days of old this film former was some natural product resin such as amber mixed with a vegetable oil such as linseed oil. Upon exposure to air the resin and oil reacted ("dried") to form the cured varnish film.
Now days the film former is a mixture of chemicals that are either man made (synthetic) or chemical alterations of natural products such as vegetable oils. The possible combinations are bewildering. I know of one company that made more than a hundred different formulations of stuff to make the film former as demanded by different customers for different applications.
One of the synthetic chemicals used to formulate modern varnish is "urethane". Urethane referrs to the arrangement of atoms in the molecule as described in an above post. Many years ago when urethane modified varnishes were first made available a "urethane modified varnish" was a product of exceptional durability. You could not dent these finishes with a finger nail and on a floor they wore for years. My "urethane" finished floors lasted under the assault of 2 kids and a dog for 15 years and refinishing involved merely scuff sanding and adding another coat of varnish. So it came to pass that durability became associated with the name "Urethane". Sadly this varnish got banned by EPA for consumer use because the urethane component used in this formulation was judged too toxic for consumer use.
Over time varnish companies found other ways to incorporate urethane chemicals into varnish in ways that resulted in formulations considered less toxic. There are a zillion ways to use the urethane chemical modification in a varnish, so now days the fact that a varnish contains a urethane component means nothing in terms of the properties of the cured film.
No matter how the urethane chemical is used, in the end it becomes reacted into the final varnish film. No matter how these films are formulated in the cured state they are all polymers of urethane, polyurethane(and other stuff) - "poly" meaning many and "mers" meaning chemical units, in this example urethane. (Think of a polymer as a freight train where the assembled train is the polymer and the "mers" are the individual cars) In the old days the urethane was the linkage that hooked the freight cars together. Now days the varnish in the can already has some of the train assembled with urethane links and maybe this is why these varnishes are called polyurethanes.
