Re: OT: Re-Roofing
Fred Davis
>Ken,
Roofing is a area inhabited by amateurs , crooks and some reliable roofing contractors.
Without any guidance ,all of them will opt for the least expense and hassle to themselves.
Since I was a General contractor for many years in the state of California , I specified the roof covering , not the roofer and got a good job every time.
Roofers are not entirely to blame for a cheap skate approach to roofing , since they deal with insurance adjusters every day , who are not competent to survey damage and home owners who want the job done cheaply , so they can share the insurance claim money.
All of that aside , your steep roof pitch is in your favor shingle life wise and the 15 LB is adequate.
I personally from experience at looking and removing old roofs and seeing how the 15 LB. felt had dried out and deteriorated from age will opt for 30 LB. felt every time.
Beyond that , in some areas of your roof if you have them ,valleys for instance should have metal valley runs, preferably baked enamel, unless you can afford copper which is even longer lived.
Allowing the roofer to weave the shingles in the valley helps him labor and material wise and does you a disservice which you need to avoid.
Also insist that all roof jacks and chimney flashing be replaced with new.
If your in a area of country which needs it , have the first five feet covered with waterproof membrane to avoid water damage from ice damming.
Inspect the gutters for rustout and the fascia board behind them and the shingle mould for dryrot and replace before reroofing.
Lastly pick a roofing contractor that is licensed and insured and has a waiting list of customers and lives locally.
Good luck,
FredD
