question for experienced re-sawers- band saw fence
Bill Tindall, E.TN
>I recently bought an ancient Delta 20" band saw that I intend to rig for resawing. What do you recommend for a fence?
Bill Tindall, E.TN
Re: question for experienced re-sawers- band saw f
william h. falberg
>What kind of fence is on it now? What do you intend to re-saw? How often? Are you handy?
paul waddle
>If you do not intend to do(try) thin pcs,make a single pt fence and begin. There are lots of articles about this. It will be easier on the start, and later make a solid(?) fence and deal with the saw leadin one way..pw
good info
>Search the current and archived messages here. There were several significant discussions about fences and band-resawing in the past several months.
Sgian Dubh
>A single point fence works well, plus a sharp blade. Slainte.
Re: About the point fence...
Glenn Madsen near San Francisco
>Sgian's point about the sharp blade is important. Otherwise, the 'lead' or 'drift' of the blade makes for a mess, and time spent at the drum sander. This seems most important with the point fence.
My challenges were always with wanting to resaw something that exceeded the capacity of my bandsaw. Well, that and fighting with the drum sander...
Seeing Bill's work here, it's evident he has more patience, and skill, than I do.
I use the Laguna Driftmaster fence on my resaw.
Scott in Montana
answers to your questions
Bill Tindall, E.TN
>What kind of fence is on it now? none
What do you intend to re-saw? domestic hardwoods boards into thinner pieces-drawer sides and veneer, for example.
How often? I am dedicating the saw for resawing. It will have a carbide re-saw blade.
Are you handy? moderately
Re: answers to your questions
William H. Falberg
>The cheapest route would be to get some 2 x 4 aluminum square tubing acut 2' - 3' -4' etc. lengths and clamp them to your table by hole-sawing access openings for the clamps to fit your table. A little extra length on the fence is nice even when your table is short. You can stack them modularly according to your needs and vise-grip the stack together. For tall cuts you'll need to get a little fancier but that's up to you and how far you want to go with this. Mine adjust to infinite increments parallel to the blade by attaching a spine to the upper wheel housing. It's not nearly as complicated as it sounds and is incredibly precise.
[image] http://i282.photobucket.com/albums/kk264/falbergsawco/WNSkeletalFenceOne.jpg[/image]
I could not load your picture
Bill Tindall, E.TN
Re: I could not load your picture
William H. Falberg
>I sent a PM. Sorry about the image thing. Can you cut and paste into IE? It worked for me that way.
>Bill, I am not an expert at resawing. I have a 14" Delta with riser block and a home made single point fence. Mine is just a dowel screwed onto the face of a piece of plywood with brackets that hold it vertical.
I find using a feather board on the table holding the board tight to the fence to be very useful. Actually, I use only one or two fingers of one of those plastic ones that locks into the table slot. This allows me to watch the top edge and not worry about the bottom. And I can keep my hands off the board more and keep them away form the blade. This (feather board is the difference between success and failure for me. I suppose you could use a spring loaded roller also.
Actually, I have posted often about my love/hate relationship with the bandsaw. I think you have gone a long ways toward solving my problems. Having a dedicated resaw will allow you to keep the "good" blade on the saw and the fence setup for resawing. Everything can stay tuned for this job. I hate switching b;ades and have been known to risk the good blade on a bowl blank because I don't have the time or inclination to take an hour to switch back and forth. If I had the money and space I follow your lead and buy a second saw.
I suspect you will be able to set it up, account for the drift (however much or little there is) and use a straight fence.
3 things matter
Jesse Cloud
>1. fence needs to be adjustable to match drift of your blade
2. fence needs to be dead nuts vertical 90 degrees
3. fence needs to be as high as your workpiece but not much higher (so you can get the guides close to the work)
My unimpressive solution is a two part fence, one to provide for clamping to the saw table and a few inches of vertical area. Connect the horizontal and vertical parts with triangles for stability. The second part attaches to the first with countersunk bolts. If need be you can shim between the two parts to get 90 degrees. Since the second part is pretty simple (generally melamine), I don't hesitate to rip it to the appropriate height or make a new one quickly.
Re: 3 things matter
William H. Falberg
>There's a bunch of things that matter; so many I'm writing a book, in fact. For now I'll just post these pics in hopes the big tool companies will follow my lead, as they usually do. (I'm still looking for any evidence the big guys thought about lever-action tensioning prior to my introducing it in 2003) It looks like they're close behind me with the modular fence idea but it may be a while longer before they can duplicate the vestigial fence idea without totally up-dating their frames. Anyway............
Re: 3 things matter
William H. Falberg
>Here's the backside view...........
Adjustable to 8" in infinite increments, re-inforces upper wheel housing (for stabiliy), height adjusts in 4" increments, comes off with three knob-turnings, adjusts to blade "lead" (if you're still into that myth), and adjusts to blade parallelity in infinite increments. Not to mention the creme-de-la-creme "vestigial fence" for those of you who are tired of "push-off" and sniping. Lovingly brought to you by Falberg Saw Co. for $8000 because the big guys would rather copy than fund real research and development. Remember where you saw it first.
Re: 3 things matter *LINK*
Phil Smith
>There is a good post over on the OWWM.org site on a home built fence which is easily adjustable for blade drift. It's about the 3rd or 4th note down in the discussion complete with pictures. Fence is modification Bob Vaughan made for his Powermatic 81 bandsaw.
Bandsaw fence discussion
I have a few questions.
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>I saw this before, and it looks great, but I was wondering, since there are no people or anything in the photo to give it scale, how big it is.
Also, what size motor, FPM, and blade tpi etc. do you use on it?
Re: I have a few questions.
William H. Falberg
>SliceMiester is currently in design phase and has a 1HP motor, 16.5" table to top guide, 72" x 26" table-top, 8.5" blade-to-post throat width, runs a 1/2" 2TPI Timberwolf at 76'/sec. With a little money it will get a 2HP motor, 3/4" 3TPI blade. Ultimately Slicemiester will feature 14" wheels (off the shelf competitor cheap wheels), with a selection of motors up to 3HP and take (I mean really SUPPORT) 1" blades. The fence and frame design will carry through, but it'll be proportionally beefier to handle production re-sawing. The material transport, like everything else, is on hold pending funding; but I'm keepng that info proprietary for now, in hopes the antique dealers at your favorite Tool Corp. get their heads out and get behind me on some needed patent work. They know who they are and they're reading this, too. (Should we wait for China to pick this up too?) And yes, the full-blown 3HP version will still run a 1/8" blade and make some cutsey pine derby cars. It would take two minutes to change blades and convert. Can you spare the time?
