Re: OT Drywall Question
Fred Davis
>JOhn,
radius corners need no caution , they are more attractive and durable then square corners.
What needs to be addressed apparently where you live is the lack of skilled trim Carpenters. Not a problem to ask the Carpenter after one badly done corner if that is the best he can do and if so , replace him.
Since you were the customer , you have the right to complain about shoddy work regardless of how many units the builder is doing.
What you got for your lack of follow up was the standard builder practice of having Warranty Service people try to fix a problem they are not skilled at, after the fact and smooth your feathers.
Residential construction was my life for many years and I was personally repsonsible for the construction by contract or job Supt. of at least 3,200 living units of every description and what your telling is pretty much the state of affairs in building practices , with the exception of the few good Merchant builders left in the country.
Complaining to Consumer affairs depts and or contractor boards after the fact rarely give you a feeling of satisfaction, however witholding payment until your reasonably satisfied is still the best and sometimes only way to remedy situations like you described.
best of luck with your base, let me know and I will post you a sample of how one is done.
FredD
FredD
