A55 Smoothing Plane
Kinda sorta OT
Kinda sorta OT
Kinda sorta OT
McKay
>I saw the fence in the picture at a local restaurant. I would like to replicate the fence for the stairs leading up the stairs on my split entry home. I really like the rustic rusty look and would like to rust the steel. However, how would I protect the rust from peoples hands and clothing? I guess that I could use bluing and then coat it, but that would not give me the rust look. Any ideas would be welcome.
Re: Kinda sorta OT
A faux rust finish, perhaps?
Dan Mitchell
Re: Kinda sorta OT
This is pretty close... *LINK*
Grant in Iowa
>Hammered gray finish from Rustoleum is pretty close. Check the spray can aisle at your local home center and I'm guessing you'll find something acceptable...
FWIW,
Grant in Iowa
hammered
Re: Kinda sorta OT
Steven Antonucci
How is this? :-)
Steve Antonucci
>Recently completed turning piece. It was made from walnut, coated in an iron based paint, and then rusted with a "secret" mix of chemicals. Reaction takes about 2 hours, and you could drink it (no fumes or poisons)
Steve
Re: Kinda sorta OT
Here is a source, *LINK*
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>That has lots of different kinds of finishes like that and more.
http://www.sculpt.com/
Re: Kinda sorta OT
Make it out of Cor-ten steel and it will oxide....
Art Silva
>to a rust color that actually protects the steel.
Re: Kinda sorta OT
OOPS! The process is oxidize.
Art Silva
Re: Kinda sorta OT
Re: How is this? :-)
>Neat looking piece. Share the secrets?
Clint
Re: Kinda sorta OT
Re: Kinda sorta OT
GalenV
>The railing was not aluminum and anodized coated? They can produce a variety of colors. Even this would wear on the top rail over time.
I have seen anodized handrail polished to a bright finish by many hand rubbing. Maybe home use it woud last well.
You said you could blue but there is also a brown used to duplicate older black powder rifles and guns. This would be hard to finish the many surfaces.
Cor-ten mentioned would take a while to produce the rust effect and during weathering is will stain anything rain runnoff hits. Again with hand contact the surface continues to rub off. Only seeen this in plate and some structural shapes but not pipe and rod.
We made a few large filter tanks with Cor-ten but the customer ended up sandblasting and painting and then no better than carbon steel for corrosion.
I like the looks of the railing too, but I wonder if they ever had anyone snag clothes or small kids being in a public place and foot traffic by.
Galen
Re: Kinda sorta OT
Re: Kinda sorta OT *LINK*
mdclor
>Look into having it powder coated the rust color of your choice. The options are almost limitless. There is a metallic copper that might might suit your needs. No affiliation.....
HTH,
Merle
http://powderperfect.com/color3.asp
Re: Kinda sorta OT
Re: Kinda sorta OT
Al Stokka - Cambridge, Iowa
>You shouldn't have any trouble getting the railing to rust...just set it beside a $1500 cabinet saw - perfect rust-producing conditions no matter where said saw is located. ;^) Then, spray it with flat, clear lacquer to protect hands a clothing from the rust.
Al
Re: Kinda sorta OT
Steven Antonucci
Sure thing
Steve Antonucci
>It is done with supplies from www.sculptnouveau.com. The paint is the Iron B formula, and the patina was achieved by spraying it with the Tiffany Green chemical they supply. I have also successfully replicated the formula for the Tiffany Green with vinegar and salt. Using ammonia and salt (Tablespoon to about 2 oz.) will produce different colors.
All of the results can be had with almost no chemistry background and relatively inexpensively. The paint isn't cheap, but lasts for a lot of pieces. Their Tiffany Green produces a different (and better) green on copper than my solutions, but mine only cost $1 at Shoprite for a gallon. All of them cause rust on the iron paint, and the combination, which I spray from little pump bottles, results as shown.
Steve
Re: Kinda sorta OT
Re: Sure thing
>Thanks for the information. I've been using Sculpnouveau copper based finishes and patina sulutions for a long time. Now i'll have to try the iron stuff. Great products.
Clint
Re: Kinda sorta OT
I worked for a couple places that did a finish...
John in NM
>that looks like that. Ours was mild steel fabrication, de-oiled with a rinse like acetone. Alcohol would probably do it too. Then it was sprayed with a ~10% HCl solution and allowed to dry in the sun. Repeat spray after its dry and until you get a nice even coat of dusty rust. Then spray varnish over - rust will go from a yellowish brown to a darker orange brown. One place used conversion varnish and buffed it smooth, the other used Varithane diamond finish and left it as sprayed.
As with any new finishing technique, several practice runs are a really good idea as there is always a learning curve.
Re: Kinda sorta OT
I forgot one step!
John in NM
>Nuetralize any residual acid with baking soda/water solution before applying finish!
