THE WOODRAT IS BACK!
Size Router Bit
Size Router Bit
Size Router Bit
Roger Wilder
>What size of round over router bit do I need to round over the edge of a 3/4" board.
Thanks!
Re: Size Router Bit
Re: Size Router Bit
>What do you want to do? If you want to just "soften" the corners you could use an 1/8" radius bit and run it on both sides. A 1/4" bit does more and a 3/8" bit will give you a "bull nose" or completely rounded edge. Trying to do any of these with a router can be problematic. If you use a bit with a guide bearing the first side may be easy because the bearing rides on the remaining edge of the top, but when you turn it over to do the second side you may find that the part the bearing would run on has been cut away. Look closely at the bit and see who far the bearing is below the cut. If the bearing is close tot he bottom of the cut, it may be fine for the 1/8 and even the 1/4" bit on a 3/4 board. If there is lots of clearance between the bearing and the cutter, it's not going to work on the second side.
Bits guided by a bearing are not going to work in that fashion for a bull nose. You will either have to by a bull nose bit or use a 3/8" bit from both sides and set up a guide rail of some type. If you use a bull nose bit, (a bit with a 3/4" cove in it) you will have to be extremely careful with the router to not tip it and have the cutter rise or tip and cut lip on the bottom edge. Using a 3/8 radius bit from both sides requires very careful setting of the rails to keep the cut symmetrical.
Re: Size Router Bit
Re: Size Router Bit
Lee Schierer - McKean, PA
>You can avoid the problem with bearing location if you use a router table and fence instead of the guide bearing itself for the second pass to form the bull nose.
Lee
Re: Size Router Bit
Re: Size Router Bit
Fred Davis
>This is true , and if you want a more atractive ,less radical edge , try a "thumbnail bit" which will require the router table and fence setup.
If your looking to ease the edge , running a 1/8th" directly , using the bearing guide works just fine.
FredD
Re: Size Router Bit
Re: Size Router Bit
>That's funny. He said "board" but I was thinking table top. I did this recently to a table top. The top was about 34" by 84". Way too big for me to manhandle onto my router table. I flashed onto my project, not his. My shop is so small, I have to go outside to change my mind. No way was I edging that top by moving it around in my shop. Somebody would have been killed and shown up on JL's list. In my case, I used a thumbnail bit on the top side and a 1/4" radius on the bottom and feathered them together by hand.
Re: Size Router Bit
Re: Size Router Bit
Jim Dillon
>Roger,
In this case, I would suggest that you try a couple of different radius roundover bits on scrap 3/4 inch wood to see what looks best to YOU. Start with the smallest roundover, say 1/8 inch, then increase the radius till something looks nice, given your end use. Yes, this means having several router bits on hand, but sometimes this is what what works best - at least it does for me. I keep a stable of 1/8, 3/16, and 1/4 inch roundover bits on hand to try out on 3/4 inch stock.
Jim
