tapering on a table saw with slider
Matt Calder
>Hi,
I am new to this forum, arriving here with a question. I know how to cut tapered legs with my bandsaw. But, I wondered if anyone has a suggested method for cutting tapered legs on a table saw that has an integrated sliding table? Specifically, the Laguna TSS.
The reason I ask is, I have legs that are 2' long, and 2" square, and then have 4" "footies" doweled on the ends. These footies are 1" square. I am concerned of screwing up a freehand cut on the bandsaw when I cross the transition from leg to footie. I figured I could use the hold down on the table saw, and a bolt or two and get a decent stable cut that way. But I figure someone might have done this already and would be willing to share ideas. Thanks for any help.
Matt
Re: tapering on a table saw with slider
Bill White
>I'm in he midst of a tapered leg table right. Though I don't have a slider, I'm using a "sled" that will hold the leg positioned such that it presents the leg to the blade the same way each time it is rotated (tapering all 4 sides).
Bill
>Matt, I don't own a table saw with a slider and in fact can't remember ever seeing one, so I can't answer your question directly.
On a non-sliding TS I sue a tapering jig. Basically two boards about the length of the legs with a hinge between them so they will open and close like a set of dividers. They have a small stop block on the one end and a small slotted piece that allows you to clamp them at a certain spacing, similar to dividers. Lets say you wanted to taper your legs 3/4" or 3/8 on each side. Set the jig at 3/8 and taper two sides. Then set the jig at 3/4 and taper the other two sides. The first two sides have to be at ninety degrees to each other.
The length of the taper is set by marking it on the jig from the stop block. And the amount of the taper is actually the difference between the spacing at that point and at the stop block. If the jig were exactly the same length as the taper, the hinge would be "zero" and the stamping would be 3/8. But, if the jig wire longer and it opened an 1/8 at the point the taper starts, then you would set the spacing to be 1/2", the difference being the 3/8.
To avoid resetting the jig, some people use a 3/8 space after rotating the legs.
There must be a dozen ways to do this.
The geometry is that the legs is held in the jig and the jig slides on the fence. The blanks slides past the the blades, but at an angle.
Not sure how a slider on a TS would help, but it it has the requisite Stroke, you could mount a guide on the sliding table at the proper angle to the blade and spaced properly form the blade and slide them through.
Whatever you decide to do, Practice on some scraps first. Your legs a slightly more complicated than most because of the feet. Be Careful to "reference" off the same surface every time.
Tapering
Lee Schierer - McKean, PA
>When I need to make a taper cut, I use a sled to the right of my blade that just touches the blade. All it is, is a piece of 3/8" plywood with a runner on the bottom. I figure out the taper I want and mark it on the piece of wood to be cut. I use double sided tape to fasten the piece of wood to the sliding table so the edge of the plywood toward the blade aligns exactly with my marks on the piece to be cut. Place the whole thing on the table, start the saw and make the cut. Repeat this procedure for each cut.
Your "Footy" has me a bit confused. If the taper leads into a straight part at the narrow end of the taper, the cut cannot be completed on a table saw. You would have to stop short and finish the cut from the other direction to make the straight cut for your "Footy".
Lee
doug f, san clemente, ca
>Matt - I've got a TSS. Probably overkill, but I built the jig that was featured in FWW several months back. It fastens nicely to the slider on runners that fit the sliding table grooves. Works great, especially for multi-tapered legs and gives a large range of taper widths. The major drawback is what to do with the jig when I'm not using it. It's pretty big.
Have fun with your project.
Doug
Might try using the jointer instead *LINK*
Dan Mitchell
>I've used the method demonstrated in this Popular Woodworking video several times to taper legs on the jointer. Quick, easy, and it leaves a nice surface, plus to me it seems safer than using a TS.
Dan
http://fw_woodworking.permissiontv.com/index.html?
Re: Tapering
Matt Calder
>Lee,
The taper will progress into the foot. The issue I am working on is the transition from the 2"x2" leg to the 1"x1" foot. The leg is 2', the foot is 4", and the taper goes down to 0.75"x0.75".
I think your "fix it in place" might be the way to go.
Matt
Re: Might try using the jointer instead
Matt Calder
>Mitchell,
The foot will throw off the second step I think. But I'll have to think it through with the exact dimensions I have. Thanks.
Matt
Matt Calder
>I finished the tables up a while back, and finally took some photos. As you can see, the legs turned out fine. I ended up cutting the tapers on the band saw free hand and then using the jointer to neaten them up (my usual method). The footies really didn't present as much difficulty as I had feared. Thanks for the suggestions.
Matt
