How to replace the drive
North of the Border
>it's as easy as:
0) turn off your computer and remove the power cord as a safety precaution
1) buy a new drive (DVD/ CR type if you want to play and burn DVDs as well - it's about $30 - $50 or so mine is a LG 16X DVD / CD drive))
2) take out the case (usually you just remove the side panels) and take note of the cord, interface cable, etc. - the best way is to take a couple of digital pictures so you can refer to it
3) unplug all the connections from the drive and remove the screws on both sided that secure the drive to the housing and slide the old drive out
4) slide the new drive in and replace the screw
5) reconnect all the connection cables and cord.
4) plug in your power cord and turn on your computer and you should have saved yourself $50 - $100 for the installation.
Have fun - the first time may be a bit intimidating (following the above procedures helps) but the next time, you'll be a pro. Charge your next door neighbor just a glass of beer, though, instead of $50 if he or she needs your help! :-)
