Paddle switches
Howard Norman
>I ordered and received two 220v paddle switches, H8242, from Grizzly. Both switches are defective. What other reliable sources are out there that anyone has used?
Paddle switches
Howard Norman
Re: Paddle switches
GalenV
>I was trying to find where these are made as the QC sounds like it does not exist with two out of two bad.
I see they say the switch stays off till switch is "reset" but it does not say how the switch is reset.
Could both these switches be off and do they say how they are reset?
That sounds like it would be a pain if you cannot just hit the start button again. Maybe the on line description is just poor on this reset means.
Better luck on your next switch.
Re: Paddle switches
Howard Norman
>I sent Grizzly an email this morning about the problem-no response. I just called and they are sending replacement switches. Unfortunately at this time I have no confidence that the replacements will work since it was two out of two defective on the first shipment.
Re: Paddle switches
Mark Brennan
>I have used the Grizzley 220v magnetic switches with out any issues.
Re: Paddle switches
Chuck in ND
>Howard, if I was you I'd cancel that order and order the H8243 110/220V Paddle On/Off Switch. It looks of better quality like the paddle switch I bought from Woodworkers Supply.
Re: Paddle switches
Howard Norman
>Grizzly has a replacement order in the pipeline so I will wait and see what happens with the replacement order. I considered the part that you mention originally but elected to go with the cheaper part. There is no reason for them to ship defective merchandise.
Re: Paddle switches
Howard Norman
>Chuck, I just checked the Woodworkers Supply web page and indeed they look like the same switch. WS includes a box and double the price of Grizzly. However WS is out of stock and expects new stock on 2/8. Will wait and see what happens with Grizzly. Thanks for the input.
I have done business with Woodworkers Supply before with good results by the way.
Re: Paddle switches
Alex Grigoriev
>Are you testing them with the line voltage applied? My understanding that magnetic switches will turn off in case of power loss. Thus they won't stay on without power.
Re: Paddle switches
Howard Norman
>The switches I purchased are not magnetic switches but rather are mechanical switches.
Re: Paddle switches
Chuck in ND
>Yes Howard, a box does come with it from WS, and it does cost quite a bit more, thats why I suggested the other Grizzly switch. I guess what would worry me is when you do get the ordered switches and hopefully they work, how long are they going to last ? I will say that I've had the WS switch for over a year and have never had a problem with it on my Delta Contractor's saw.
Re: Paddle switches
Howard Norman
>>I guess what would worry me is when you do get the ordered switches and hopefully they work, how long are they going to last ?<
I understand and obviously I can't answer the questions. I will say that at this point in time I am not optimistic about the next two working after this experience.
