burnt up motor
burnt up motor
burnt up motor
mark thompson
>I recently turned on my old Rockwell 11-120 drill press after about two months of sitting idly by, only to have it begin smoking profusely from the motor after about 5 seconds.
-It was currently about 25 degrees
-It had seen temps of -20 degrees during the hiatus
-It started up real slow and took two or three seconds to get to full speed
...Any thoughts on the reasoning?...and how much damage is done to a motor if it ran for 2 or 3 seconds while smoking? thanks-Mark
Re: burnt up motor
Re: burnt up motor
Will Abbott
>In my experience, once you let the magic smoke out a motor, the motor is done. You may of had some condensation in the bearings that caused them to rust, or the moisture froze inside the bearing. Either way it sounds like you are going to need to repair or replace the motor.
Will.
Re: burnt up motor
Re: burnt up motor
Pete in Holland, MI
>Pull the motor off and bring it in the house, warm it up, then try to run it. Maybe you'll get lucky, but as was mentioned before, once you let the smoke out.............
Re: burnt up motor
Re: burnt up motor
GalenV
>Agree with others it does not sound good for your motor. You don't know how bad the insulation on the wire windings are. Even if it runs you may check with a neon circuit tester or voltmeter an make sure the motor case is not live from current leakage. Test case to a ground. I had a metal lathe that you could get a "tingle" from the old motor that I finally replaced.
Re: burnt up motor
Re: burnt up motor
Robby Wright
>Before you give up on the motor, check the starting capacitor and the centrifugal switch that switches it in and out of the circuit. If the switch is stuck closed, it can burn up the capacitor.
