Re: (Hijack) for John Jordan and others.
Curly Smith
>You didn't say what you're resawing but a few things come to mind:
a) Speed kills bandsaw blades -> too high a feed rate causes the blade to get hot and a hot blade is a dull blade. Take your time and let the blade clear the sawdust. Watch the back guide - if it's spinning like crazy then you're going too fast. If you've equipped your saw with a dust connection in the lower section and you have a lot of sawdust buildup on the table then you're pushing too fast. Note that "spinning like crazy" and "a lot of sawdust" are relative terms.
b) Bark kills bandsaw blades -> if at all possible remove the bark. The dirt in the bark will rapidly dull your blades.
c) Proper tension should be applied -> if you don't have enough tension the blade will deflect too easily and you'll get a bowed cut. The bow will cause friction which will heat the blade which will cause the blade to get dull.
d) Friction is not your friend. Wax your table, your sleds and your fence to reduce the friction as much as possible. The more you have to push to overcome friction the more likely you're going to push too hard and either deflect the blade or cut too fast.
d) Use the right blade -> the 1/2" 3 TPI may not be the best choice. If you're cutting stuff thicker than 6" consider moving to a 2 TPI blade, if less than 1" consider a 3/4 variable or 4 TPI (or greater if much thinner).
e) Kinks happen when the work isn't properly supported. If you're resawing tall stuff then your stock fence isn't tall enough. Either add an auxiliary fence or make a new one. Ideally, you'd like to have support for the entire height but rout grooves to remove 2/3rds of the material - you want support but you don't want full contact along the height because of the friction. If you're cutting flats on log sections consider using bungee cords to straps to hold the wood. If the piece moves while cutting you'll get a kinked blade.
f) Consider making a very simple resaw sled. You'll need a piece of 3/4" plywood, two aluminum t-track hold downs (as shown here: Large Aluminum Hold Down ), a 3/4" runner for the slot, a couple of bolts and knobs, and a Bessey clamp. The plywood should be a few inches longer than the maximum capacity of your Bessey clamp, the width should be slightly more than the width from the blade to the outside edge of your table. Cut a groove for the runner in the plywood base about 1/8"less than the distance of the blade to the slot (you'll cut off the excess later), make sure that the runner is snug but slides freely. Wax the table, the bottom of the sled, the slot, and the runner. Tap the runner into the bandsaw table slot and then cut off the extra width from above - you now have a cut-off sled for the bandsaw. The blade will ride the inside edge until you change blades (and/or the drift changes). Place the Bessey Clamp 1/8"-1/4" from the cutting edge, and mark bolt hole locations for the two hold downs. Drill and countersink holes for the bolts, and then install the hold downs to firmly clamp the Bessey to the sled then simply tighten the Bessey clamp to hold the wood (note: a 1/4" piece of plywood under the jaw will help it slide without requiring loosening of the hold down). The Bessey clamp will hold the work securely and the hold downs will hold the Bessey clamp securely to the sled. Since the table and the bottom of the sled are waxed finger tip pressure is all that is needed to push the piece through the cut. Just remember to account for the kerf when making the cut.
