Pulley speed Chart?
Pulley speed Chart?
Pulley speed Chart?
Sawman
>Does anyone know where I can locate a chart that would show what RPM's I can get with elctric motors and different sizes pulleys? I want to set up a furnace blower and play around with different blower speeds. So I would also need to know what size pulley to use on the blower.
Thanks
Re: Pulley speed Chart?
Larry Marker in Alabama
>YOu don't really need a chart -- the speed ratio is the ratio of the pulley diameters. If the motor has a 2 inch pulley and the blower has a 6 inch pulley, the blower will turn at 1/3 the speed of the motor.
However, there is a neat online calculator at
http://www.csgnetwork.com/pulleybeltcalc.html
which will also give you belt length.
The part that causes some to struggle is determining what part of the pulley to mesure the diameter at. The general rule is to measure the diameter at the point where one half the thickness of the belt makes contact. (In genral, it doesn't make that much difference.)
Larry
Simple arithmetic
Ellis Walentine, Host
>The speed of the driven pulley is the ratio of the drive pulley to the driven pulley multiplied by the RPM of the motor. So, if your drive pulley (the one on the motor arbor) is 3"� and the motor speed is 1725 rpm, a 3" pulley on the output shaft will run at the same speed. A 4" pulley will run at 3/4 (3"/4") of the motor speed, or 1294 rpm. A 2" pulley will run at 3"/2" of the motor speed, or 2588 rpm.
Steve Schoene
>The basic calculation is straightforward. The speed of the driven pully is the ratio of of it's diameter divided by the diameter of the driving (on the motor) pully multiplied by the speed of the motor. A 1720 ron motor with a 2" diameter driving pully belted to a 4" diameter driven pully would be 3440 rpm.
There are some wrinkles about the difference between the outside diameter and the effective diameter of the pulley, and if multiple speeds are desired even more complications obout choosing cones to give the desired progression of speeds. That's beyond my ken, and not I think what you are looking for.
GalenV
>Think it was noted before if you run the blower too slow you may have a thermal switch that will shut the unit down as the jacket will get too hot. Blower should run on the thermostat and balance for delay on and off.
You can buy a variable pulley that you screw apart and lock with a set screw to change the diameter at which the belt runs on. If you have good adjustment to the motor base you can run one size belt.
Think we all need to move to a warmer climate this year. Cold spells hitting too many states. And this is global warming?
Galen
Here's a link *LINK*
Lee Schierer - McKean, PA
>Here is a link to a speed calculator. Even though the math is simple sometimes a calculator makes it clear.
Pulley calculator
Something to keep in mind
Gary Camp, Bend, oregon
>Changing pulley sizes / blowers speeds changes the CFM (the desired effect, I assume) it also changes the amperage draw of the motor. The spped of some blowers is set with an amp clamp on the wires and then adjusting the pulley diameter until the amp rating of the motor is reached. On some units having door open on the cabinet can change the amount of air getting to the blower, that can also change the amp draw of the motor. Early in my bldg maint. career I was working on a blower motor (480v 3ph 10hp) with the blower compartment door open. The fuses blew. Our electrician was sure the motor was bad, after carring the replacement upper 2 flights of stairs it blew the fuses too. I was letting the blower get an unrestricted airflow so it was moving more air than it was setup for. An extreme case? Sure. Still it is something to be aware of you when start changing airflow volumes. You don't want to burn up a motor by making it work too hard.
glc
Non-overloading blowers
GalenV
>Gary
Most all residential furnace blowers are of the non-overlaoding wheel design so they can run unrestricted intake all day long. We used a lot of recycled furnace blowers for weld fab shop fans.
For our Forced Draft Aerators we also purchased non-overloading wheel design from Peerless Blower in 1/2 to 10 hp versions.
You got muscles to carry a 130 to 150 pound 10 HP motor up stairs, but then I could do a lot when I was young a LONG time ago!:>)
Galen
It was a two person job
