DeWalt 734 planer won't feed: cold rollers?
Dan Mitchell
>Went out to my unheated shop to do a bit of planing, 1st time out there in 6 weeks or so, due to the "unheated" aspect. I'd say it's between 40 & 45 out there right now. Went to plane a piece of hard maple, about 3/4" x 10" x 18". Even with a minimal cut, the board won't feed. Tried some smaller pine pieces, one also ~3/4" thick but only about 2" wide, same story. Won't even start feeding, & if I give it a shove, it stops moving as soon as I stop shoving. "Shoved" portion is planed fine, but no feed. Machine is about 1 year old, has seen minimal use. Is this a result of the rollers being cold? Anything I can do about it, other than bringing the planer inside for a few hours (which would be a PITA due to the way it's mounted)? It was fine the last time I used it, again, maybe 6 weeks ago.
I was REALLY hoping to make some sawdust! ;-(
TIA
Dan
