Any sources for roller stand feet?
>One of mine is missing - I suspect one of my cats. Another one is cracked. So, I might as well replace them all. Sears was no help. I don't have the model number on the stand, so they can't find me part numbers.
It's a nice roller stand. I can always turn something, but it won't be flexible. I can also put some PVC pipe ends on the metal, but again, that wouldn't be too flexible either. I'm willing to listen to other suggestions also.
TIA
Re: Any sources for roller stand feet?
Chuck in ND
>Well it's hard to say when you don't give us a descrption or picture of what it is you need. I'd suggest checking the hardware store in the specialty bins.
Chuck in ND
>Another idea if you need round ones are crutch tip ends, they can be found in hardware stores also. Again, I'm just giveing blind suggestions.
Here is a link. *LINK*
>I like your suggestion about crutch tips. They may be a bit large in diameter though. The pipe has an OD of ~1".
Sears Work Stand
Good hardware or possibly auto parts store
>Chuck suggested crutch tips, which I was going to suggest if your stand's base piece is round. The rest of my suggestions below apply to square tubing, or more generally to anything regardless of shape.
My local hardware store has some selection in tips for square metal tubing too. While the tips are strongest at the intended bottom - what will be your side - my recollection is there was enough "meat" to provide some feet for tubing on its side.
You might, with enough enthusiastic cursing, be able to force round rubber or plastic hose of the right size (if you could find it) onto square tubing. Calculate size needed by measuring the dimension of your tubing (if square, multiply one side by four, of course), then the needed inner diameter of the hose by dividing this answer by pi (22/7 or 3.1415etc.). If you get a match in common hose diameters, which are usually in 1/8" increments, then you get to decide how to make round into square. Consider your possible choices, and, if there's one that's thermoplastic (gets soft when warm) but suitably sturdy at room temperature, that would be right nice; use your heat gun or your or TLOYL's or a neighbor's blow dryer to get it warm (I'd suggest leaving the tubing out in the sunlight, but, in your part of the country right now, that's not a productive idea...maybe August).
You could buy rubber sheet stock (used as gasket stock by plumbers and auto mechanics), cut into sizes you can wrap around the tubing, and glue it - Goop or weatherstripping adhesive should do it - around the tubing ends. Hold it in place with suitable tape while the glue dries. Think about how to forestall "unraveling" at the ends. A gusset of the same stock applied over the joint and glued on should do it. If you live anywhere near a tire store that serves trucks, you might be able to score a blown inner tube (I think some trucks still use tubes...) and spend even less.
Self-vulcanizing electrical splicing tape sticks to itself with a vengeance and builds thickness pretty quickly. It's soft, so you would need to cover it with friction tape (famous in my youth for not sticking to itself or much of anything else for long, but it may have improved). This might be a spendy solution.
I have no experience with these, but bicycle people and golf people have various kinds of tapes they use on handlebars, golf clubs, etc. I don't know whether any of these would be durable enough as feet, or whether they're more foamy and soft for the hands.
Drill from below and thread tubing for adjustable feet. If your shop floor is irregular, this may be the best solution of all.
Re: Here is a link.
Chuck in ND
>The crutch tips come in a couple different sizes, you should be able to find some that fit.
Thanks for the ideas. Off to Hiawassee Hardware.
>in the morning. They have the off the wall stuff.
