making cove on tablesaw
Don Evans
>I'm familiar with the method of setting up two guide boards with enough space between them to run a board through and raise the blade for the depth for cutting a semi circle out of a board for cove moulding.
My question is sizing it: the depth is easy, just raise the blade that amount. However, is there a way to calculate the width of the cove based of the angle the board will travel across the blade?
Also the diameter of the blade would also come into the calculation, it seems.
Obviously I have not giving this much thought yet, but I admit my ignorance with this particular procedure, can anyone help me get started here.
An example would be, I want to run a cove that would be 1/4" deep and 1.5" wide in the surface of a board.
Don
