Removing epoxy glue
Dave in Haverford,PA
>Client has a sideboard with a foot that was broken off and repaired with epoxy. It has come loose and needs to be reglued. How do I remove the old stuff?
Removing epoxy glue
Re: Removing epoxy glue
>Brute force works really well. If the glue was mixed properly and is cured well, that may be your primary choice.
Alternatively, you can soften some epoxies with methylene chloride. As you may not have access to the pure stuff, you may have to go with a methylene chloride containing paint stripper. Unfortunately this also does a number on any finish. A gel type may work and be somewhat "contained". Sometimes gentle heat will help.
Good luck.
Lee Schierer - McKean, PA
>Try heating the wood to 220-250 degrees F. The wood should not burn, but the epoxy should get softer. At 300 degrees F the epoxy should melt, but the wood should be safe. You'll need to wear gloves as these temps will burn your hands.
lee
Chicago Bob
>try acetone or methylene chloride or trichloroethane ( in order of soventcy capabilities) - can be found at most big box stores in quart containers at less than $10 /each. use very good ventilation, safety glasses & wear neoprene disposable gloves at a minimum - do not smoke. apply the solvent and let it swell or soften the epoxy - you may have to dig out the epoxy a bit at a time and reapply the solvent. depends on the epoxy type, degree of cure, age of joint,etc
hope this helps
Bob Haines
Try denatured alcohol
Dave Smith, Longview, WA
>Hi Dave,
One of the things I learned during research on drying wood turnings with alcohol is that alcohol dissolves epoxy. It was discovered by turners who used epoxy to attach blocks to the bottom of blanks. After roughing out a bowl and soaking the piece in alcohol they found that the epoxy was dissolved. Alcohol is used to thin epoxy for better penetration and to extend the pot life. I use alcohol to clean up my invariable stick mess associated with epoxy use.
Be careful and work safe.
Dave Smith
Snow birding in Mesa, AZ.
