Two questions on drying green wood
wilbur
>I haven't had much experience drying wood, so forgive the newbie questions.
1. If I have a long board that's somewhat green (not freshly cut, but not fully dried yet), and I notice some cracks in the end, should I cut them off to try to prevent further cracking? Or should I leave them be if I can afford the wasted area?
2. Same board, and I already know how I want to cut down the board for my project. Is it advisable to cut the board down now to pieces that are, say, a few inches wider and longer than my final dimensions? Or should I let the board dry as a whole?
Re: Two questions on drying green wood
Steven Antonucci
What I'd do:
steve antonucci
>1. Do not cut the ends off unless you think the crack is still growing. If you do, you'll expose fresh, wet end grain, and it will likely crack again.
2. I never cut wood until I am absolutely sure of the shape I need, so I wouldn't cut it. While having more smaller boards might seem like a way to dry them faster, I think that "faster" is the enemy of good drying. You might let them dry for 6 months, then cut them down, then dry for some more (oversized) before final cuts...
Steve
cutting and sealing *LINK*
>wilber,
You didn't provide much information.
If the ends are well sealed, some end cracking is normal and I don't think there is much you can or should do. If the ends are not sealed, the ends will certainly crack as they dry, sometimes severely. You typically lose 6" or so from each end, often much more if a long crack propagates down a board with internal stresses. Sealing with Anchorseal, wax, or even some kinds of paint will do. (link) Ideally, logs should be sealed immediately after felling the tree. I buy Anchorseal in a 55-gal drum for my sawmill but you can get just a gallon from Woodcraft.
If the ends are not sealed and you seal them now, unless you get sealer deep into the existing cracks some moisture will still exit there so some say sealing now is worthless. However, since the moisture primarily leaves through the long straws of the pores and very slowly through the side grain, and the cracks basically expose the side grain to the air, I simply seal the ends of logs and lumber which has already started to crack. If you have enough extra wood the cleanest thing would be to cut off the ends and immediately seal the fresh cut. Note however, that even with sealer you may still get some cracking on the ends depending on the drying conditions, the species, and the specific boards.
If you cut the boards into narrow pieces they will dry a little faster, but not much. However, you risk more warpage - the entire board might dry straighter. For one thing, it's harder to properly sticker and weight narrow boards. BUT - this also depends on the drying conditions, the thickness, the species, and more importantly - the specific boards and where they are cut from the tree. For example, thick, a wide-quartersawn board will be much more stable than a flatsawn board taken towards the outside, cut on an angle down the length of the log, or worse, cut from a twisted or leaning tree. A wide piece might cup but a narrow piece is more likely to twist.
As long as the boards are properly stickered and weighted, protected from the weather, and there is adequate airflow from the sides and up through the middle of the stack (if large), I'd seal them (if needed) leave them alone.
Others may have other opinions.
Woodweb - sealing logs
ps
>If you just have one board, try to weight or clamp it to something (with stickers for air flow) to minimize warping.
no, and no
Bill Tindall, E.TN
>1. If I have a long board that's somewhat green (not freshly cut, but not fully dried yet), and I notice some cracks in the end, should I cut them off to try to prevent further cracking? ......End sealing has been shown to only be effective when the log is first cut and then it is of marginal benefit. These ends have done done what they are going to do. Bottom line, don't fret over end splits. The ends of lumber cut near the center of a tree will always split no matter what you do. I have dried thousands of feet of lumber and never end coated anything except 16/4 lumber. None of the dry kilns in my area (200,000 bdft capacity) end coat which should give some indication of how useful end coating is.
2. Same board, and I already know how I want to cut down the board for my project. Is it advisable to cut the board down now to pieces that are, say, a few inches wider and longer than my final dimensions? NO, this approach would be very wasteful. It is vastly easier to dry lumber straight when it is long (presuming the base of the pile is straight.
>I agree with all of the above.
Let me add a thought. When I start cutting lumber down to size for a project, I have a tendency to cut the pieces nearly to the final size. Often, this is a mistake. If you have the wood available, you should cut the pieces slightly oversized. That way, if they warp or move due to internal stresses or for whatever reason, you may have a chance to straighten them and save them. Another example. I find the ragged ends to be annoying and they seem to offend my sense of order and neatness. I used to trim them off. This is the part on the ends of the boards that have the splits and perhaps a somewhat ragged chainsaw cut. Now I leave it on there. My planer leaves snipe on the ends. By waiting until the last minute to cut off the ends, I cut the snipe off with it.
Re: cutting and sealing
Fred Davis
>JOHN ,
I find what you say to be true and it's obvious when I pick up lumber at Kansas Hardwoods which does not seal , even though they have a drum of AnchorSeal that I asked them to get and use.
They claim not enough time available to seal logs and when I point out the crack on each end of each board , they scale down to the next foot of length.
When I get lumber from a professional lumber company like Paxton in K.C. and or one or two mills in Missouri the ends are sealed and I have very few boards in a unit with end cracks.
FredD
>Fred,
Those who justify not sealing seem in general to just not want to bother with the time and expense and accept the end degrade as normal.
We had a gentleman try to get a connection going with our woodturning club to try to sell us turning wood. When I told him few would be interested in unsealed logs and slabs with end cracks he didn't care - he said sealing was too much work. I process a huge number of turning blanks and my experience is that most pieces over 1"x1" will probably crack if not end sealed.
I found a big improvement even when cutting 4/4 boards. I try to seal the ends of every log as soon as possible. (Of course you can often get away with not sealing some species, during some seasons, and at some locations.) On occasion I've missed sealing one end and guess which end had the big splits.
Brushing is messy and time-consuming. Large sawmills will often spray the sealer. Since sealing is costly, I read that some sawmills only seal the more valuable logs.
Fred Davis
>John,
In California where they do not shed construction lumber, the contractor lumber yard I dealt with often used a hand held Wagner sprayer with orange latex paint to seal units of lumber that the mill had not.
In that environment , the heat would turn a lot of the lumber into pretzels , but they turned it over so fast , that they said it didn't make any difference, but I have sent back to the yard many units of lumber that had to be straight , like 4x6 girders and never got a argument, but the waste is tremendous.
FredD
