Ellis help Chat room problem
John Veerkamp, Western Mo
>Still cannot get in. I downloaded the latest Java version. After the screen pops up with the cuppa and it apparently loads, when the cup screen clears the screen with the sign in box used to come up here. Now just a blank screen comes up. Any ideas?
John
Re: Ellis help Chat room problem
Fred Davis
>takes about two or three minutes for the sign in box to load on my PC.
You might try waiting for a while if you haven't already.
FredD
>15 minutes didn't do it. It was working fine until last Wed.
Howard Norman
>It took about five minutes for me last night to get the sign in window on the screen. It has always been very slow for that window to show up. After that screen everything seems to act fairly normal for me on the chat room. I don't visit it too often anymore because of other commitments.
Satellite is the issue
Ellis Walentine, Host
>Howard, I was on Hughes Net until last summer, and I experienced the same problem you did. I'm convinced that it has everything to do with the latency of the satellite signal. Signing onto the Chatroom requires your browser to negotiate with the server. Each exchange takes time to go up and down to/from the satellite. That's why the applet takes so long to load. I don't have a solution for satellite users except to be patient. I got into the chat every time, though it often took a minute or two to complete the login process.
Sorry about that.
Ideas. No solutions.
>John, regarding the chatroom, I changed a couple things last week: I made the chat box larger and I added a Woodfinder banner to the screen. I suspect that one or both of those changes may have affected your log-on time, but I can't confirm it.
I have reverted the code to the previous iteration. Try it and let me know if it changes your log-on experience. It seems to work faster for me.
Re: Satellite is the issue
Howard Norman
>Ellis, satellite if my only option other than dial up at this time so I am stuck with the present situation. My cell phone carrier is Alltel which has recently been acquired by Verizon. I know one person that uses a Verizon cell connection and is happy with the speed. I may look into that after the dust settles on the Alltel acquisition. I know that it would require a cell phone amplifier and that is a few hundred dollars so it is not something that I will be doing in the short term
Yeah, I can relate
>I only bought the satellite option because Verizon didn't offer any high-speed connections out here in the boondocks. Since then , they have extended their DSL service the extra couple thousand feet to my property, so I'm now using that service instead. It's crippled at this distance from the relay station, but it's almost as fast as HughesNet and without any of the delay. Plus, I could roll it in with my phone bill. No brainer.
I just wish the telecom industry could expand fast enough to satisfy the demand.
Re: Ideas. No solutions.
John Veerkamp,Western Mo
>Ellis,
That fixed it. Thanks,
John
Hmm.
>I wish I understood why that happens. Oh well, I'll play with it some more. Maybe I can set up parallel chatrooms and people can choose the ones they want. Not enough hours in the week.
