OT - What's this called?
North of the Border
>An outline image? Anyone with a publishing or design background?
Also, how to create something like that - what software to use?
Thanks.
North of the Border
Thanks.
Portrait
>Of the Invisible Family?
Re: Portrait
North of the Border
>Yes of the family. I'm looking for the term that people in the printing industry use for that kind of artwork. Do we say an outline portrait?
Re: OT - What's this called? *LINK*
John McGaw
>Don't know what it is called but it could be done: 1) manually by drawing on a new layer over the original and then turning the orignal off or 2) automatically by a plugin or standalone application. An example of #2 might be as shown at the link below or it might be one of the more advanced vector tracing programs.
Trace Plugin
Emulating the function
Rod Peterson -- Ormond Beach
>I don't know what it's called, but I approximated the effect for a photo of my dad's bomber crew taken at crew training. I took a copy of the original photo, and by adjusting brightness and contrast apropriatley, I ended up with a sort of washed out, half tone image, where the individuals were recognizable insofar as location compared to the original was concerned, but was light enough to not interfere with the labels later applied in a black typeface. Attached pic without labels.
Rod
Ultimately, however…
>I wound up using the original and just used a white typeface for the labels as seen in the attached. That, however, is not the answer to your question.
Rod
PS: picture taken at Pyote, Texas, AAFB. I'm not sure of the year—probably early '44. There's a museum there, now, called Rattlesnake Air Base Museum or something like that. I remember my dad saying it was in the middle of nowhere.
Re: Ultimately, however�
Randy Johnson Connersville IN
>I notice that even by 44 when the Germans had already been able to examine a lot of Norden bombsights due to the number of downed bombers,the Norden in this picture is covered with a bag. I've read that it was done for security reasons or I would just assume it was for protection. Anyway, nowhere do old habits die harder than in the military.
Tom
>I don't know what it's called, but my photo-editing program has a couple of ways to create or approximate it (a real old version of Paint Shop Pro). They are in the 'effects' menu, edge and topography. I also remember using a program that had a function called 'coloring book', but can't remember which app it was.
Paul Woolson
>Are you thinking of "Line Art"? (as opposed to half tone art) When the press makes a solid "line" of a single color it's called line art.
No Name, But How to Do It
Mike Fitterling
>There is no printing industry name for that I know of, but I have done those quite a few times. I would call it just an "outline drawing."
The way I do them, and IMO the best way, is by using a graphic tablet. I would print out the picture that the outline will be the key for, in a size that will fit under the transparent sheet on my tablet. Then I trace directly over the images with the stylus, creating outlines in Illustrator. Once everyone is outlined you can either do different colored strokes to delineate each person (with a key, of course) or simply type labels. For years the president of our publishing company would do his family's Christmas card that way, with a color image on the front and the outline inside.
Cheers,
Mike
drawing with a potato
>North,
I've made several of these. On one I put a piece of tracing paper over the photo and drew the lines. It only takes a few minutes. On another I traced on a layer in Photoshop. BTW, I use a tablet and pen when drawing on the computer - drawing with a mouse is like trying to draw with a potato.
Due to the contrast issues in photographs, I suspect you will never find software that will delineate the edges as well as doing it by by hand, probably not even close. Image processing edge detection algorithms need contrast to work. Edge algorithms will certainly make lines, but with a group photo things will run into each other and you will end up with a jumble of lines instead of what you are looking for. You could use this as a starting point but it would take a lot of cleanup and would not look as good as a simple hand tracing.
BTW, I never heard these keys called anything special. I just call them keys. How about "identification key"?
Cool!
>My version of PSP (6.02—not the latest, to be sure) has, under Image, Effects/Glowing Edges. I don't know why they call it that, but it delineates the edges just exactly the way I wanted them for my purposes, although negative. You can also adjust for how harsh or distinct you want the edges. Then I simply did Colors>/Negative to bring it back. I was about to upload an image of how it turned out, when I noticed Image/Edge/Trace Contour. Perfect. Why didn't I find this five years ago?
Thanks for spurring me to play around.
Rod
Re: Cool!
Bill Howatt
>Glad you found the commands. In Paintshop Pro X it is under: Effects - Edge Effects - Trace Contour.
The other posters comment about needing somewhat high contrast is true.
Billh
Who's who…
>It occurred to me that you might like to know a little about this crew. The unit was the 457th Bomb Group, comprised of the 748th through 751st Squadrons. My dad was in the 750th. The group was one of three assigned to the 94th Combat Wing, 1st Air Division, 8th Air Force.
Only two are still living: Ralph Evans, the A/C (pilot) is kneeling, left. Elroy Peters, the bombardier, is kneeling right. I met Evans, years ago—probably around 1956-8—and we've corresponded recently. I met Peters at a 457th reunion in Colorado Springs in 2001. I've also attended two mini-reunions held at the old base in England biennially.
My father is third from left in the back row. It's funny, I guess everyone thinks their father is tall, growing up. I know my dad was about 5' 10"—not short, but average or so, but he seems to be the second shortest on the crew. The shortest, Patterson, far right, was, guess what? Ball turret.
Note all the Swedes—Peterson, Patterson, Carlson, and Nelson.
There are fewer and fewer of these fine men (and women—my mother also served, although obviously not in combat) left every year. In my lifetime I remember us celebrating the last three Civil War vets in the '50s. I know we're now at or near the last of the surviving WWI vets. Although I might not live long enough to see it, the last WWII survivors will certainly pass in many of our lifetimes.
Sorry for going way off topic.
Rod
Thank you all! I think I'll call it Line art.
North of the Border
Re: Who's who�
Frank G
>Very difficult times for them. They did it without welfare, handicap parking places, but with pride. Certainly true Americans.
Here's an example
Ellis Walentine, Host
>This is a group shot from the 2007 5-Barns Picnic. I used Edge Effects > Find All.
Re: Here's an example
>Hey, better delineation than usual! Looks like a convention where everyone's wearing a badge.
I'd call it - "Paint by Number" looks like it.
GalenV
Re: OT - What's this called? a "Legend"
Michael Holden
>I assume that this is posted by the image without the numbers, and if so, it would be called a "legend" just like in maps.
