200+ woodworking book reviews
OT: Makita angle grinder
Dean Lapinel
>Just got a variable speed makita angle grinder from amazon.com Options listed on the page were dewalts metal cut off and general grinding blades. I assumed that since they were listed as "options" they would fit. Unfotunately the screw in type from dewalt won't fit because of the guard.
Amazon doesn't carry makita wheels for the 4 1/2 (bummer since I have the free shipping deal with amazon).
the question:
Does this machine accept many other wheels or only makita? Are they hard to find?
Thanks for any guidance.
Dean
Re: OT: Makita angle grinder
2 sizes?
Mark Goodall - ATL - Tooljunkie
>I buy them in bulk and haven't shopped for any in a while so I can't recall the sizes exactly, but I believe the abrasive cutoff disks come in two arbors sizes...... something like 5/8" and 3/4" (or something like that). MY DeWalts and Milwaukees use the larger size and I think the Makita uses the smaller size. But both are readily available from what I remember seeing.
Happy Woodworking!
A Wright
>I have had a Makita 4 1/2" angle grinder for about 10 years and it is still running strong after going through a lot of wheels
I dont think I've ever bought a Makita brand disc but pretty much any 4 1/2 wheel will work. Although the 5" size is more common, I can find what I need at pretty much any store with a big tool department(Home Depot, Lowes, Sears, etc.)
At least 2....
John in NM
>I remember about 10 years or more ago Makita only made a 4" grinder that had a smaller size arbor and would only use their wheels - could be it was an older standard or something and they were the only ones making them anymore.
When I bought a Makita grinder about 5 years ago, it was the standard thread (I think its 5/8-11 for 4 1/2" disks). I've never tried a 5" disk as I usually run with the guard off and they look like they overhang the motor too much for my tastes.
At any rate, mine uses the same disks as everybody else's. I'm not sure if the old Makita with the funny arbor is still available, but I believe it was when I bought the one I have.
wheel fit
>I use several angle grinders. I get wheels from Northern Tool (cheap price and quality), my local welding supplier (good quality) and in a pinch, from Home Depot. Make sure the arbor hole is the right size. I would not want a smaller wheel (that would be like a half-worn larger wheel) and a larger wheel would not fit in the guard. (Do NOT operate without the guard!)
On my Milwaukee 4.5" I use screw-on wire brushes, grinding wheels, cutoff wheels, and my favorite - wheels with overlapping sanding flaps (don't remember what they are called but they are the best for surfacing.)
But that's a good question about what will fit the Makita. To date I've only used Makita wheels on my 4.5" Makita grinder so I've never thought about it. So I went out to the shop and checked - all of my grinding wheels with the same arbor size and all the screw-on wheels and brushes fit both the Makita and the Milwaulkee. They both have 3/4" arbors and the same thread. Note that these grinders have reversible flanges so you can use either thick or thin grinding and cutoff wheels.
Love those flap disks!
John in NM
>Aggressive yet smooth, they're the best for quick cutting cosmetic stuff. One place I worked used a lot of scotch-brite disks on a rol-loc pad for final smoothing. Expensive, but man did they work well! Word of warning though, the rol-loc pad is too tall for a guard.
