rust
rust
rust
Ronald from NW Ohio
>I have a snow blower and when winter is over, What is the best thing to use to spray on the metal to help to prevent rusting? I know this is a wood site but i know you guys are good at knowing all things so help me out!
Re: rust
What's a snow blower? :)
>Seriously though - this may sound weird - cooking oil spray. The guys down at the tractor/mower place recommend using cheap cooking oil spray (store brands) to spray the undersides of mowing decks.
I figure if it will work with a mower, it should work with a snow blower and not be toxic or hazardous.
Re: rust
Re: What's a snow blower? :)
Ronald from NW Ohio
>would that not attract ants?
Re: rust
I use WD40 after I use it and
Dustmaker Mike
>I just spray it down with a cheap spray oil. When I bring the SB in the garage after running it I let it warm up in the garage then spray it down with WD40. I use cooking spray on my mower deck all summer long but to winter it over I use an inexpensive spray oil.
Re: rust
Re: rust
Dale Stansbery
>If you have a place that the overspray won't be a problem and you can get it dry, spray the wear areas with a cheap can of rust prevention paint like Rustoleum. I do that on my farm equipment like planter coulters and plow shares and it works great until the next season, no need to prime. On the other hand, if you store the snowblower in a dry garage or shed, I wouldn't bother.
Re: rust
It's oil, not sugar
>It is biodegradable and won't harm the environment also.
Re: rust
Boshield T-9
Bill Tindall, E.TN
>This stuff was developed by Boeing for applications like yours. In the spring we have water condense on the bed of the planer outdoors in the lumber shed. This stuff prevents rust in this adverse situation.
