Way OT....Why does dry skin itch?
>We had a long post the other day about dry cracked fingers. I am wondering why my ankles itch in winter? I would happily scratch them until they bleed. (and do, sometimes, in my sleep)
Is it just the dryness? Or does the dryness allow some other problem like excema or psoriasis to rear its ugly head? I am running a humidifier/vaporizer beside my bed and that helps, but there is a sort of "disconnect" in this. About the only thing I have found that seems to work is Vaseline. A coat of grease. You would think water would be great, not grease. Or is the grease just retaining the moisture in the skin? If it is something else like a fungus or bacteria it would seem there should be something better than Vaseline. Can't wait for spring.
Re: Way OT....Why does dry skin itch?
John E in SC
>Don't know that I can explain the physiology of it, but dry skin is itchy skin. Every winter, we get a "rash" (pun intended) of dry, itchy skin problems. (I'm a family doc.) Vaseline is great - helps hold the moisture in. Water, particularly hot water, (with or without soap, but worse with soap) actually dries out the skin by removing the natural oils. You might try a little hydrocortisone cream or ointment off and on to help control the itching some also, but what you're doing is pretty good.
HTH,
John
The dermatologist is my best friend
>Hello Barry,
I need prescription meds to control my itch/dry skin. Its worse than most. Vaseline is something I use once a day in the mornings, gently and sparingly applied and rubbed ineasily. At night before bed, I use either the prescription clobedasol (sp) or more vaseline, depending on how bad the outbreak is. I also use a moisturizer both times.
George
Joseph Mulherin, Sr
>Barry, I have found that the skin does become sort of brittle and dry over the winter months. I suggest the following: coat the hands with any hand lotion and use the cutoff finger gloves like they use for arthritis. Also, apply lotion to your feet and put on socks to keep the feet smooth. I know these items can be worn thru the day also without inconvenience or mess.
>A couple of years ago the doctor told me that several things can cause winter itching, from dry skin to fungus and bacteria, perhaps encouraged by winter layers of longjohns, etc. He also said people tend to shower too often in the US, especially in the winter, which can dry out skin and make things worse. He prescribed a "Clotrimazole and Betamethasone Dipropionate" cream. I don't know exactly what caused the problem, but with one application several months of itching went away in a couple of hours and never came back.
I use Bag Balm...
Don in Vancouver,WA,USA
>I bought a 10oz can of Bag Balm in Walmart's pet section several years ago and it seems to help on my feet and ankles. It is a lanolin based ointment...Lanolin acts as a waterproofing wax that aids sheep in shedding water from their coats. Dairys put it on their cows udders.
Al Stokka - Cambridge, Iowa
>Barry,
I have the same symtom in the winter. I could scratch my ankles and calves until they bleed with little relief. What I have found on my own is to message a liberal amount of hand lotion (most any brand, it seems) into the affected area immediately after showering. Waiting until the itch starts and then applying the lotion has a greatly descreased effect.
Al
Fred Davis
>Barry,
I think I said this once not long ago, but if your Ankles itch like mine every winter , it is because of the dry air.
Humidifiers work regardless of your opinion of them.
The Vaseline works because it retains moisture in the Skin.
Another product very similar to Vaseline is Albolene, works the same way.
I use a moisturizer ( Vaseline intensive Care lotion) fancy name aside ,it works and in conjunction with a Humidifier , the best treatment available so far.
For reasons unbeknown to me , the itch did not start until I was about fifty and guys I have talked to , including Doctors seem to think it is one of the blessings of old age , along with Arthritis and no short term memory.
Some swear by Gold Bond products, anything that would inhibit loss of moisture will do the trick , if your a natural products only guy , you might consider Bear grease.
FredD
Something that might work for others..
Larry Rupprecht
>This was suggested by my physician. He learned it from his grandfather and not from any medical training. Wet the itchy part...hands, feet, elbows, calves, whatever....with warm water, leave dripping wet, and "slather" gobs of Vaseline or any brand petroleum jelly onto the part, thoroughly rubbing it in and adding more warm water any time it gets thick and sticky. Keep up the rubbing in and adding warm water until it turns whitish and your skin just won't take anymore. Wipe gently on a towel and go about your business. Do this before sleeping at night and the skin will be good for many days in the morning. Cheap fix but don't expect to pick up any dropped coins right away...Your mileage may vary....and it does seem to lessen the number of cracked finger tips for me.
Jim Pugh, Elyria, OH
>Look up "chillblains" and it might explain what is going on. It can be worse in older homes that have cold drafts across the floor in winter. Also, as others said, rub the affected area well with a vaseline skin lotion right after showering. Last but not least, use all your will power to not start scratching. All will help.
Paul Waddle
>My skin drys out and seems not to absorb any water or oil.
When I was 62,it hit me all at once-nearly drove me crazy. I went to the doc,but had only marginal relief. Did this for 3yrs.
I have subsequently found that if I use Gold Bond products,the itch doesn't seem as intense and I use it all year round. If I wait until winter,its too late. I don't know why my skin won't absorb moisture more redily,I know what will happen and I prepare.
I too think there is some phychology that make the itch more intense,but I want relief and don't worry about it.
For cracked fingers-especially thumbs,I coat the ends with liquid skin bandage . pw
Cornhuskers, $2.47/7oz.@Walmart
Art Silva
