Yesterday's senior moment
Randy Johnson Connersville IN
>For way over a year, one of the need to do projects has been getting ducting run over to the lathe to help eliminate at least some of the dust generated by sanding. When I ordered the dust hood it was out of stock. Before it arrived I took a bad fall, and only now am I able to hold my arm overhead long enough to do any ceiling work.
When the ducting was originally installed I used hex head self-drilling screws. When I started the extension yesterday all I had handy were Phillips head screws. Since the job required some disassembly, I was having to change bits back and forth on the cordless drill. (I�m one of those seeming rare people who only has one.) I had just reinstalled some of the hex head screws and reached to the top of the ladder to get the Phillips head bit. It wasn�t there. *%&$#^, it must have fallen on the floor. I spent five minutes or so crawling around on the floor trying to find it and another five searching over every flat surface anywhere near to where I was working. Ha!, I finally found it. Where, you ask? I was holding it in my teeth. Having Terry Thomas dental work is really great if you like using your mouth as a third hand, but only as long as your brain is still functioning normally.
