OT-Torches
Sawman
>I cannot recall what kind of torch I would need for disassembling frozen/rusted metal parts. I know propane is not hot enough. Is it acyetelene?
Thanks
OT-Torches
Sawman
Thanks
Map gas ?
del schisler
>if you are using the Blue tank gas Change to the yellow Map gas it is hotter than the Blue tank That may give you the heat you need
Propane, MAPP, MAPP+Oxy, Ace+Oxy
Re: OT-Torches
Pete in Holland, MI
>If heat won't affect the entire part, and the size isn't too big, I use my gas grill !
I restore old steam engines and some parts & screws can be rusted pretty tight. If heat won't bother the other components, put it on your grill for an hour or so on high, turn it off, then come back in the morning when it has slowly cooled off. Breaks down rust every time !
