Persimmon vs Cedar....
John L. Blue
>I've got a 20 pound cut of each, just wonderin' your
favorite to use for the base of a small table. thanks
in advance! Blue
Re: Persimmon vs Cedar....
>Green? If it is green, whichever cracks the least.
More info needed
Ellis Walentine, Host
>Just about any wood can be used to make a table base. If you're talking about using a log section, the cedar is less likely to split apart. On the other hand, it will be considerably lighter, so there are engineering questions to be answered.
If you're going to saw these pieces into boards and make a base with traditional joinery, again, either would be fine. In that case, you probably want to choose on the basis of appearance, perhaps workability.
Fill us in on the table design and the pieces of wood in question.
Re: More info needed
John L. Blue
>appreciate your response, it's almost 20 yr ol', an 8" chunk
chainsawed off to use for the base of this table, the persimmon
is still full of water, as it is only 6 mos. old, but, sorta
wonderin' how things like that work out sometimes. Blue
