OT Truck Cap
OT Truck Cap
OT Truck Cap
Sawman
>Does anyone have a lead on some type of "quick connect" for truck caps? Mine has 6 bolt and not with a clamp system. It is a pain to use. Is there aa better way?
Re: OT Truck Cap
Re: OT Truck Cap
>On my wife's Dakota, I used two 3/4" stainless bolts through the cap's inner rim and bed rim on each side, with fender washers to spread the pressure. Easy on; easy off.
Clint
Re: OT Truck Cap
Re: OT Truck Cap
mdclor
>I have used 4 three inch "C" clamps for a temporary solution with no ill effects.
Re: OT Truck Cap
Re: OT Truck Cap
Glenn Madsen near San Francisco
>I had C-clamps holding mine on for the 8+ years I owned the last one.
Never removed the cap in that whole time. Having a second, open truck, helps.
Re: OT Truck Cap
C-clamps........
Basil
>....with a strip of wood, top and bottom to protect both cap and truck bed. Check several times for tightness after installation and any reinstallation (next 2 or 3 weeks).
Re: OT Truck Cap
Re: OT Truck Cap
Brad Chenoweth
>The shop I bought mine from used aluminum "clamshell" type clamps specifically made for the purpose. They have worked well and are a breeze to remove (1 bolt). If you use C-clamps, I would re-check them regularly. I once had a cap installed that way come sliding off after a year. Not a pleasant experience (for the cap, either.)
Brad
Re: OT Truck Cap
Re: OT Truck Cap
Gary Camp, Bend, Oregon
>I'd stick with the bolts, and get a 3/8" socket adaptor for my cordless drill or impact driver. Spin em on - spin em off, probably faster with the drill than you could tighten 6 clamps, and a lot more secure. On anything small I almost always use my drill, even if I have to break it loose with a ratchet. I hardly ever pick up a screwdriver or 1/4" drive ratchet.
glc
