circular saw to table saw
jackdolan
>Has anyone had success building a small platform to use circular
saw as a table saw for small cuts?
jackdolan
Neveer Built one
Lee Schierer - McKean, PA
>I haven't built one, but I owned one for a while you could mount a router, jig saw or skill saw under the table. It even had a switched outlet so you wouldn't have to reach under the table to turn the motor on and off. I sold it a a garage sale a few years ago. I don't recall who made it. It used some "C" shaped metal brackets and thumb screws like tabs to hold the tool against the bottom of the table.
Lee
Re: circular saw to table saw
GalenV
>They use to sell a cheap particle board stand you were to be able to mount your skil saw under but imagine they realized it is a dangerous way to use the tool. If you left the retractable guard in place you could not cut small pieces and force the guard down out of the way. If you did not use the guard it was dangerous tool.
I did not want to tie up my skil saw as it was better suited for dimension lumber and portable.
I imagine you could build a better table and invest in a better skil saw but then you are beter off buying a table saw. Even a cheaper 8" bench top saw would be better than trying to use your skil saw.
I've tried to make do myself over the years but sometimes it just ended up more work and not to happy with what I got.
Galen.
ncguy77
>Bad idea it's gonna bite you.
Boy, I would rather have the cheapest, noisest, chinese POS table saw made out of dioxin laden plastic for $59 then try to use a flipped over circular saw.
Lowes has a full 10" Skil with stand for $99
Sears craftsman for $99
Craigslist!!!
Chuck in ND
>Small cuts ? If your refering to crosscuts, a miter saw would be the more appropriate and safer machine for that task.
Re: circular saw to table saw *LINK*
A Wright
>I've seen a few plans for this type of jig before in magazines and on the web over the years. Here is one example. (disclaimer: I have not built this or anything like it)
circular saw table
steve mackay
>The only C-saw I've ever used and / or owned is my big worm drive rig so I may be off base here. But I can't BEGIN to imagine the potential mayhem if that sucker was'nt mounted "just right" and got loose or side-ways. The injury factor is high enough with a TS thats engineered for the task. But then, I'm the original accident prone child !
A Wright
>I had seen that web site in passing a few weeks ago and remembered the article when this thread came up. After I posted the link, I took a closer look at the article and I have to say that I would be scared to use that unholy mess.
if youre really interested in building one, I remeber a better interpretation in one of the mainstream magazines (probably either Wood or Popular Woodworking)
Tom MacGregor
>Keep your eyes open and make sure everyone you know is aware that you're a tool junkie. I got a cast iron top 10" 3hp tablesaw (original price +/- $900) with a premium fence at an estate sale for $100. I couldn't get them to knock the price down any farther so I got them to toss in a 15 speed mountain bike. I also have two vintage 8" cast iron top saws in the shed waiting to get cleaned & tuned. Both were given to me by people who just wanted them out of the way. I wouldn't settle for a dangerous scabbed together saw. There's too much used iron out there waiting for me to find it.
Lee Gordon
>The commercial one some of the others have mentioned was manufactured by a company called Hirsch. I don't know if they are even still in business. I still have mine but it is buried under so much stuff in my basement, I wouldn't know where to look for it.
jackdolan
>Thanks to all who responded. Sounds like a real bad
idea. "Ten fingers" Jack Dolan
Lee Gordon
>An even worse idea is something I once saw a guy do (he was working on a construction crew doing some renovations to my house several years ago). He made a plunge cut with his circular saw through a piece of 1/2" plywood, screwed the saw to the plywood, flipped the whole thing upside down onto a pair of saw horses, and used it as a makeshift table saw. Naturally, there was no provision for a fence or miter gauge, so he was free-handing everything.
Angus Barclay, in New Zealand
>Hello Jack,
for several years I used a pressed-steel version of the thing you described. For all its many faults, it was OK as a "break-down" saw to rough-size parts before final sizing with handsaws and planes. I recently bought a cheap Ryobi table saw that has a noisy universal motor and is made out of plastic and cast aluminum - and in spite of the low quality this cheap piece-of-junk saw is still a 100% improvement on the previous contraption.
If you need (or want) a small table saw, then buy one of these small cheap bench-top Chinese-made saws rather than waste time with an upside-down circular saw.
regards
Angus Barclay
