Looking for an odd hinge
Chet Kloss
>I'm building a pedal box for a musician friend of mine and I need a special hinge that I've seen before but don't know what it's called. I'll do my best to try and describe it.
One side of the top of the box will have traditional "twist clasps" that will lock it in place. The hinges on the opposite side of the top will have to let top be released when the clasps are open.
What I've seen in the past is a hinge where the "pin" is attached in one barrel and slides freely into the other. When its together it functions as a tradional hinge but when you slide the top to the side, the pin, which is attached to one of the barrels, de-couples with the other allowing the top to be lifted away.
I hope that makes sense (and I hope someone knows where I can buy some).
Thanks,
,,,,,,,,,,,,,,,,,,,Chet
