Copy carver Build
Copy carver Build
Copy carver Build
Gerald Caryl
>I am presently in the process of fabricating a carving machine utilising components that I have laying around the shop. The machine will incorporate basic disciplines of the carving machines readily found on the web. I am not favoring any of the machines "out there" as to design, nor am I coping any machine exactly to a company's manufacturing specs. My Materials on hand will determine the out come and design. That said, I drew up my plans and gathered up my materials. I was quite amazed myself, as to how much "stuff" I had laying around and what type of Machine I ended up with on paper.
Hear is a list of what I have so Far. [1] 10 lineal Thomson 1 1/4"
diameter bearings. [2] 41 ft of cold rolled hardened 1 1/4" steel shafting. 30 feet 2" square 1/8"walled tubing. [3] 2 3/4hp porter-cable routers, "I have decided on a double headed machine, as I have a need to copy many duplicates from the original shape". [4] numerous roller bearings and nuts and bolts.
If anyone out there has built a carver or owns a Gemini, I would be interested and hearing from you. I believe mine will end up being like a Gemini but more heavily built. Also I am incorporating some of my own unique innovations to the machine which I have not seen on any of the Machines out there. for example, 2 cutting heads. Well off to the shop I go, I am mounting the lineal bearings to the shafting to day.
Re: Copy carver Build
Dick Coers
>You've got 41' of 1 1/4" hardened rod laying around the shop? You're my kind of guy!!!!! Heck with those kind of components, you might as well make it a CNC. Sorry, no help, just envy!
Gerald Caryl
>I already have a CNC, but the work I have, can be done with a carver better. I have a lot of different parts to make and programming the CNC is not practical in this job. The parts are such odd shapes that I can do them with a carver faster. Ever try to program a CNC to shape a "shoe", inside and out for example? Every machine has its pluses and drawbacks. I have had a 5x10' CNC for ten years. Believe me, you have to spend a lot of time programming when you can be out in the shop producing. I think a Carver that is heavy duty and not a toy will work good together with a CNC in a wood shop.
Dick Coers
>I know all too well. I run a 5'x10' 5 axis Motionmaster for a day job in a model shop. My behind gets a lot more tired than my feet on that assignment.
Gerald Caryl
>I will send you soom pics if you like of my cnc and the carver if you like. I will have the carver done sometime next week. The carver is going to be slick,,,
Re: Copy carver Build - Please...
Carol - now back in Dubuque, IA
>post the pics for all to see.
Thanks.
