Novice question on finishing
Rod Rentz
>When using sanding sealer, do you stain before or after. My Daddy said that dumb questions are the ones you don't ask!
Rod Rentz
Re: Novice question on finishing
>I've done both. If it is a wood that is likely to stain unevenly, I've put sanding sealer (or equivalent) on before dyeing or staining. I've also used it as a first coat after staining, particularly if I'm washing another color or stain over the other stain.
Not enough information
>What kind of wood? What kind of stain? What kind of "sanding sealer"? What kind of final finish? Too many unknown variables to come up with a definitive answer. But lots of conventional wisdom of questionable merit.
Clint
Fred Davis
>All respect to your Daddy , but there are no dumb questions, you may find some of the answers may make you scratch your head though.
FredD
>Your Dad is right. By asking you can avoid many mistakes. And the rest of us can avoid saying "If you had only asked, I could have told you...."
Finishing is a topic nearly as vast and complicated as "making" whatever it is you are making. Something I wish I knew more about. The answer to your question is Yes, No, Sometimes, and Maybe. As indicated by others, someone here who knows far more about finishing than I do would need lots more information to answer your question and even then there might be a dozen different approaches to it.
Many people believe that half of the project is making the piece and the other half is finishing. (I personally am not "into" finishing and wish there were the magic spray can or rag I could just pass over the piece and it would be beautifully finished.)
There are a number of books on the topic. You need to start by learning what finishes and stains are compatible with each other and try to avoid ones that interfere with each other.
You probably need to break some eggs. Practice. Take some scraps and sand them like your piece and then try out the finish you want to use. Put the stuff on just as you intend to finish the piece and see if it works. I am really learning to like shellac. Zinsser, either in a quart can or a spray can. It is subject to damage by alcohol and ammonia, but it is very durable other wise and smells pleasant and dries quickly. I also like lacquer for a more durable(?) finish. Shellac is compatible with almost any stain or dye and can be used as a barrier coat.
Steve Schoene
>Don't let people scare you off. Just come back and give us an idea of what it is you want to finish, how it will be used, the wood it is made from, and essentially what ideas you have about what you want it to look like and there will be responses that give some meaningful assistance.
