Hardware help?
Hardware help?
Hardware help?
Pat Evans
>I need to be able to level, from the top because of access issues, a 3/4" mdf auxiliary band saw table. Obviously, the top must also be flat and clear of obstructions. The space between the top and the bench it sits on varies from 1" to 1-1/4". I'm thinking of drilling thru holes and using t-nuts on the underside of the table with hex head bolts inserted from beneath. I can cut a screwdriver slot in the end of the bolt for adjustment from above. It's kind of rudimentary, but should work. Anyone have other suggestions?
Re: Hardware help?
Re: Hardware help?
Bob Burnet
>Rather than "make" the set screw, see McMaster-Carr. http://www.mcmaster.com/ They carry all kinds. Enter "set screw" and look at what they have. I like the idea of using a T-Nut on the bottom of the MDF. I would use a set screw that has a allen wrench socket to set the depth.
Re: Hardware help?
Re: Hardware help?
Curly Smith
>What you suggest would work but I'd use leg levelers instead of bolts to get a larger base.
