crown mauldings
crown mauldings
crown mauldings
Hamish MacAllister
>I'm installing a 5 1/2" crown maulding that's a dentil cornice. It is paint grade and will be covered in paint. Do i still need to cope it in the corners or will glue and caulking do the job well enough?
Re: crown mauldings
Re: crown mauldings
Mamc
>I have done just about every room in the house and have always coped the corners. I recommend it!
I still use caulking to fix small gaps from the crooked corners that wont line up no matter what, and to make a nice seal between the wall/ceiling and moulding.
My corner joints (some 10 years old) are still solid and tight.
I am not so sure they would be if I had just mitred them versus coping.
Coping also cuts down on the number of mitre cuts you have to make as usually 2 walls can be done using just straight end cuts depending on the length of the wall.
As much as it would have saved me tons of time, I was always afraid of having ugly gaps open up after doing all that work to try and make the moulding look great.
With coping you are pretty much guaranteed you are not going to get larger gaps from seasonal movement.
Just my opinion
Re: crown mauldings
Cutting corners when cutting corners
>I tried doing it without coping.... it's actually harder.
Obviously cutting a mitered corner is easier to cut, but it's much hard to fit. A cope joint is a little harder to cut, but so much easier to fit.
I taught myself how to cut cope joints properly. Once you get it a hang of it, it's realy quite easy. I've seen jobs done by professionals who just cut 45� miters in the corners of the rooms, and well..... it looks terrible. You can tell when you see a job where they cut corners when they were cutting the corners. Everyone wants things quick and cheap and well.... it looks like it.
A properly coped corner will look infinitely better, now and in 20 years, compared to a mitered corner. Just my opinion.
I figure that when you spend the money on materials, you might as well do it "right".
Happy Woodworking!
Re: crown mauldings
Re: Cutting corners when cutting corners
Hamish MacAllister
>that's a good point...1800$ for 200ft of dentil cornice deserves a job done well. thanx.
Re: crown mauldings
Fred Davis
>Hamish ,
every poster has it right on copeing the corners.
That said you need to may particular attention to the Dentil detail and try to have the same reveal on each side of the joint.
Not always possible , but well worth the try.
FredD
Re: crown mauldings
Hamish MacAllister
>that, of course, is my biggest concern. wondering though...coping is still the best way on 22.5 acute corners? keeping in mind, it's all being painted...
Re: crown mauldings
Re: crown mauldings...ALSO...
Hamish MacAllister
>is there a jig configuration that would make the coping easier?
Re: crown mauldings
Fred Davis
>cope inside corners , mitre outside corners, if you decide to mitre the inside corners, it can be done fairly decent if you prepare in advance , some wedges about seven inches long and tapered from a 5/8ths thickness to nothing.
These are best used when necessary between the ceiling and the crown moulding. Also plan on a goodly amount of caulking ;-))
FredD
Re: crown mauldings
Fred Davis
>I backcut the moulding to reveal the profile and cut that using a Bosch jigsaw and a 1/8th wide blade made for tight corners riding directly on the wood.
With a little practice it will surprise you at the speed you can produce a perfect cope.
FredD
Re: crown mauldings
Re: crown mauldings
Justin Szeliga
>I try to get the dentils to match up with the outside corners as it seems that the insides don't look as bad if not matched real well. Have fun, cutting copes on dentil crown is an adventure.
Peace
Justin
