OT-Increase Height of Concrete Floor 2"
howard
>I am extending a bedroom into old garage, difference in floor heights is 2"(garge floor is lower). Total area of the garage being used is 2' by 11'. What is the best approach to bring the floor up to the level of the existing bedroom?? I was thinking of using bags of premixed concrete, but how do I ensure a good bond. Thanks for any help.
Re: OT-Increase Height of Concrete Floor 2"
Joseph Mulherin, Sr
>Howard, you had better check with the building dept in your city to make sure the room extension will be allowed and be within the proper building codes.
Now, if it is allowed, roll some concrete adhesive all over the garage floor ... like contact adhesive glue. Then install the 2" of concrete you have planned and allow for some expansion joints. Rugs or tile will cover the joints, but you do not want to later have the floor crack from expansion or such.
Fred Davis
>Howard,
on many occasions I have extended a Kitchen as much as four feet into a existing garage in the most heavily regulated building environment in the UA, namely California, without any static from the building or planning departments of the various jurisdictions.
As long as the minimum length and width of the garage space was met and the integrity of the firewall was not reduced, then there was compliance .
If your present bedroom/garage wall does not have a two hour fire rated drywall or plaster ,then you will definitely be required to upgrade that aspect.
Also if your existing slab is in good condition and the proposed wall is merely a curtain wall , it is much easier to deck the difference in height with a wood subfloor.
FredD
Fred Davis
>in the U.S.
David Hay @ Denver
>I'd be tempted to think about a wood floor. Put down down a vapor barrier followed by ~1 1/4 in sleepers scribed to match the slope of the floor. Then fill the space between the sleepers with some kind of rigid styrofoam sheets and top it all off with plywood glued and screwed to the sleepers.
I think you'd end up with a much warmer room than otherwise. We have a family room that is so cold...I wish we had had room to put down some insulation when replacing the flooring...
David
Another vote for sleepers.
>You'll have a much warmer floor. You can get treated 2 x whatever and put it down as the base and then put some plywood on top.
>We don't know what the bedroom floor is. Concrete? Wood? If it is concrete I might go with the concrete bonded to the garage slab. If it is wood I would go with the sleepers and insulation and plywood. I might go with the sleepers anyway because they will be warmer. Also, the floor covering would make a difference. Carpet will cover a multitudes of sins and is a pretty good insulator.
howard
>Thanks everyone, I think I will use concrete since it's a small area. I appreciate the help and now know what to do.
Fred Davis
>As a rule I am not any slower then the average citizen , but tell me , why would you want to make a simple, easy job, that will provide a warm subfloor , that you can use immediately rather then wait until the moisture leaves, which can be longer then you think, not to mention the difficulty associated with bonding of one new slab to a old one, regardless of bonding agents?
FredD
