How much warping should happen when ripping?
>I'm building a set for the playhouse. Anyway, I grabbed several old 2 x 4's (relatively straight) to rip into 2 x 2s. I did not expect what I got. These were relatively straight. I ripped one of these guys and I ended up with a good 2" deviation along the 8' length. I was quite surprised. The deviation was towards the inside of the board.
I had purchased the 2 x 4s about 9 months ago for another show. They sat upright in the "bin". They were 16' long. I crosscut them to ~8' to before I brought them home to rip. The backstage area does have roof leaks and not much in the way of temperature control. I did check for straightness after crosscutting.
I have seen this a couple of times with air-dried, but not kiln dried.
Re: How much warping should happen when ripping?
It happens
Lee Schierer - McKean, PA
>Construction lumber is not dried to the same level as cabinet grade lumber and as a consequence often will bow when ripped. Most of the time leaving the lumber in your shop for several weeks to a month before ripping will take care of the moisture problems, but not always. Of course it depends on just how wet it was when y ou brought it home. A moisture meter comes in handy for cutting stuff like this.
Lee
Ideally never if its dried right
Bill Tindall, E.TN
>...and the tree it was cut from didn't have issues -reaction wood, etc. But, as was said it can happen.
