board foot
board foot
board foot
John Rosengarten
>How do I correctly measure lumber to find "board feet"? The dealers I have spoken to all sell in board feet or lineal inch, the inch one is easy, but I am not sure how to measure board feet.
Re: board foot
Re: board foot
>The "definition" of a board foot is 1" thick, 12" wide and 12" (or 1') long. As an example, I might get a board that is nominal 1" thick and about 9" wide (on average) that is 10' long. So 1" x 9" x 120" = 1080 cubic inches. 1080 cubic inches/144 cubic inches per board foot = 7.5 board feet. Or if you prefer, 1" x 9" x 10' = 90 inches-feet. 90 inches-feet / 12 inches = 7.5 board feet.
Re: board foot
Re: board foot
Dean J in MN
>JL gave a nice example above. The key to remember is a board foot is a volume, not a length/width/thickness thing.
1 bf = 144 cubic inches.
So a board foot comes in many shapes. Long and skinny, short and thick, etc.
1 inch thick x 1 inch wide x 12 feet long == 1 bf
1 inch thick x 12 inches wide x 12 inches long == 1 bf
2 inches thick x 4 inches wide x 18 inches long == 1 bf
3 inches thick x 3 inches wide x 16 inches long == 1 bf
etc...
-Dean
Re: board foot
VERY interesting . . .
steve mackay
>I've always just picked out my boards and let the Lumber Dude figure out the board feet and price then I paid up. When I got home I used my framing square to "square". Thats all it was to me. One day I was flippng through either FWW or PWW and there was a blurb about the BF table on the square. Just for kicks I brought the square into the house and MADE myself learn what, at least ONE, of those greek tables were on it. NOW I understand HOW BF works. Now about those rafter tables on the square . . . those STILL give me The Willies !
Re: board foot
Re: board foot *LINK*
>Remember that the board foot measure is for the green, unsurfaced lumber. For more than you want to know, the link below has some discussion.
The WoodWeb site also has calculators - look in the sidebar on the right.
Wood Web discussion
Re: board foot
Lumber is a natural product
Forrest Addy
>Lumber is a natural product having considrable variability. While the offical definition of a board foot is a green board one inch thick one foot square, the actual yield is often different. It's common practice to allow 1/4" on the width and thickness for milling but there is warp, wind, and cup ro consider if flat material is the goal.
"Stack run" is a term referring to lumber of a particular grade as it comes from the yard without regard for defects, moisture content, or distortion. That may be acceptable for large projects where many pieces are requires each board in the stack is selected for its application. Thus warp and defects may be incorporated or worked around. A small furnature project requires that each board be selected for a specific use and the stack may have to be high-graded by the purchaser.
Even then a board foot of rough lumber will likely yield a third board foot (actual bulk) of finished product. The waste goes to milling, rippings, remnents, and bits and pieces. So a wise purchaser never scrimps on board footage particularly on "character woods" and purchases enough material to see the whole project through to completion.
There always room for the scraps too large to discard, right? I bet all the rippings I have stashed in the racks and leaning against the wall were laid end to end they would reach to the moon. One of these days I'm gonna need some kindling and I'm ready.
Re: board foot
actually, for hardwood the rules are precise......
Bill Tindall, E.TN
>The measuring rules for hardwood lumber are precise. There is some discussion of these rules in my article on hardwood lumber production in the Articles section.
Presuming the lumber is measured according to the established rules, for unplaned, or S2S, lumber you will pay accordingly: The surface square ft are determined and this value is multiplied by the nominal thickness the lumber was sawed at, for example 4/4, 5/4/8/4 etc. For domestic hardwoods the length is nominal, that is, a board 12' 4" long is measured as 12'. There are handy rules for measuring as illustrated in the Article.
Retail operations have all sorts of screwy ways of measuring so it is best to ask when buying from these places.
Re: board foot
I was relating BF
Forrest Addy
>I was relating BF masure to actual material requirements. If the sawyer was on the job and his equipment working right the green planks will be right on the money. But funny things happen after the grader and the drying shed. The purchaser lays out his rough mailorder walnut on the bench and has to decide just how to work around the goofy grain, tight knots, work holes, checks, and other defects. Sometimes you can't get a blanket chest from 30 fb of rough walnut because defects or warpage.
Your point is market lumber measure is a precice system and I agree. My point is that lumber measure cannot be taken for granted: the rough dressed lumber required to complete a project may well require somewhat more material than indicated by calculating from the cut list unless you pay premium prices for small lot hand selected material. Small projects just plain work out that way.
Re: board foot
Lee Grindinger
Maybe in your world, but not in the real one
Lee Grindinger
>While a board foot is a precise unit of measurement in the world of perfect boards out in the real world of real boards it's anything but precise.
By the way, in your precise world is a twelve foot 5 3/4" long board twelve feet, twelve feet six? Is that 6 and 3/4" wide board 6 BF or 6 1/4? Is that 1 3/8" thick RS board 5/4 or 4/4?
I've used tally sticks, I've watched graders and their crews use tally sticks..., it's anything but precise.
Explain the difference between net and gross tally.., and then make it in terms the original questioner can understand and use as he buys lumber.
It is NOT a precise world out here in the real world..., it's the one in which I live.
Lee
Re: board foot
answers to your query
Bill Tindall, E.TN
>Acccording to NHLA grading standards the answers are:
By the way, in your precise world is a twelve foot 5 3/4" long board twelve feet, twelve feet six? this board is measured as 12' in length. In fact anything between 12' and slightly less than 13' is measured as 12' in length.
Is that 6 and 3/4" wide board 6 BF or 6 1/4? Presuming it is 12' long, or actually anything between 12' and 13' long, the tally is 7 bd ft. The only equivocal measurement would be on a board exactly 6.5". These pieces are alternatively rounded up and down to average out in the the tally.
Is that 1 3/8" thick RS board 5/4 or 4/4? Clearly 5/4 as 5/4 lumber cut on a circle mill will usually be cut 1 3/8" green. If it is some wacko thickness, for example a taper, then it will be measured by what it will plane to and be graded as a "mis-cut".
NHLA standards demand that independent tallies agree within a small percentage on dollar value, which includes both determining bdft and grade, with grade being less precise. Two honest people measuring a 1000 bdft pack of lumber will get the same answer to within a few bdft.
If the lumber is not sold by NHLA standards then tally is imprecise until buyer and seller agree on the rules to be used. I have seen anything from cubic feet to pounds used on exotic stuff.
Re: board foot
Thomas S Stockton
>John,
Others have explained board foot really well my advice is that I usually avoid wood dealers who sell hardwood lumber by the lineal inch unless it is something exotic. The reason I say this is because those dealers that sell by the lineal inch are set up to sell mostly to hobbyist and are usually on the expensive end of lumber costs. I have never lived in an area that didn't have a good hardwood dealer that was willing to sell to people buying single boards. There are some simple rules to follow.
1. If you go through a stack of wood re-stack it, if you don't know how ask, they will be thrilled that you care.
2. Don't expect to buy part of a board, some places will cut a board up but most won't. If they cut it up expect to pay more.
3. Don't be high maintenance. Asking questions is fine but don't expect them to treat you like it's Macy's or something they aren't your personal shopper. Also don't expect to get in and out quickly, if their busy it can take a little time.
4. Don't get in the way and watch out for forklifts.
5. bring everything you need to tie down your wood, they will supply a red flag if asked.
6. They will remeber you, good or bad so be respectful and ask questions if you don't know what to do.
7. Use Woodfinder to find a place in your area or join the local woodworkers group and ask them what dealers are good to work with or dealers willing to ship to you.
And last but not least ( not to offend anyone) don't buy your wood at the local large home center you will pay way to much and get low quality.
Tom
http://www.woodfinder.com
Re: board foot
cutting boards
JL once pointed me towards a dealer in Atlanta willing to cut up boards, a boon especially to woodturners wanting only small pieces.
Atlanta Wood Products will cut whatever you want from the end of any board or slab as long as the remaining board doesn't get shorter than 6' (I think). When I was there, they told me not to even worry about that - they would cut whatever I wanted. The prices were not bargain basement, but the selection was astounding. I took home some wonderful pieces of exotics.
Note that this was a few years ago - I don't know if anything has changed.
