The Shop Door
The Shop Door
Alan Young
The Shop Door
Alan Young
>Mystery, Magic or Mayhem?--The Shop Door--What lurks behind it---?
What can be deduced from a look at the Shop Door? What are your own thoughts when opening or closing the door to your shop?
My own shop door is far from an artistic expression. Just two pieces of plywood with a drop board lock---painted with one sloppy coat of white-primer. I went for years without a door on the inside entry to my basement shop. And there was more than one consequence to this structural omission-Aside from the dust that was allowed to flow out of the shop and into the "family storage" areas, the lack of a door also gave "Mr. Big Guy"- our free range cat, an invitation to explore the sawdust piles which he preferred over his own box that was positioned 6 feet outside the shop entryway. So I finally through these doors up just to keep him out of the shop.
It is ironic I suppose that after several years of Mr.Big Guy's' "shop visitations" I finally mounted these two swinging plywood sheets for doors..Yet within a month of doing so he had a kitty heart attack and died. So each time I approach those shops doors my first thoughts are usually diverted from what I left behind those doors to a brief memory of Mr.Big Guy.
Re: The Shop Door
Re: The Shop Door
Alan in Little Washington (NC)
>I call this my "stairway to heaven." It leads from the kitchen to my over-garage shop. I made the door at the top. It has a number of distinctions: Though similar to many half glassed doors, I designed it myself, it is the first interior passage I ever made, the white oak used was milled from logs harvested when they cleared the lot. I didn't have an interior door bit set so dissasembled cabinet door bits to cut the profiles. I entered it in the Freud door contest, but it does not stand a chance.
Re: The Shop Door
Re: The Shop Door
steve mackay
>Dude put the commercial door on before I bought the joint. But, why change it. Inside this door I can indulge every hair brained idea and no one can do anything about it. It gets done MY WAY. The right way. When I walk in, even though pepole send me checks in the mail for what I do, I know I'm going to do what I'm most pasionate about, what I love. Inside I'm the smartest, best looking person on the planet. Inside the house I may have faults. Out here its "How clever dear", "Thats wonderfull honey" and "I'm positive you could make a wonderfull ___________ for me sweetie ". Through this door passes the biggest ego in town !
Re: The Shop Door
Re: The Shop Door
Jay St. Peter - Southern, MD
>My door is a 5' wide exterior double door of painted luan leading into the other half of my basement. Unique because I spec'ed it as having a 3' side and a 2' side that is normally fixed. That way, I can use the space behind the 2' side as shop space until I really need to get something large through the door. Then I need to move my planer. Exterior door for "sound proofing".
Lately, my thought when I walk in is "I hope it's dry in there". I had an incident a couple weeks ago where my diswasher leaked down into my shop and I don't have 100% confidence that it is permanently fixed. The affected area remains clear of equipment for a while. Luckily, only some scrap wood and my Festool MFT top were ruined. I was able to use the old MFT top as a template and make a new one with a piece of scrap MDF that wasn't damaged. I was very lucky where it decided to rain down. Hmmm ... I think I'll go down there tonight and make sure all is well.
Jay
