WE'VE MOVED TO A NEW SERVER
OT_ Furnace Blowers
OT_ Furnace Blowers
OT_ Furnace Blowers
Sawman
>Any HVAC guys out there?
I have a solid fuel furnace that came with a Dayton direct drive furnace blower. I was wondering if anyone has and idea of what I could use to have a quieter unit? Also are the "old" belt drive blowers quieter?
Thanks
Re: OT_ Furnace Blowers
Chuck in ND
>I don't think it's the motor on blowers that make all the noise, I think it's the movement of air that is the culprit. So I would say to your question, probably not.
Jim McFall
>If the motor is multi speed, you may be able to slow it down some but be careful that your still moving enough air to take the heat away from the unit. Maybe adding more outlets will help. less static pressure means less noise, If your confident that you have enough return air supply then just adding additional outlets, or making them bigger just might do the trick. You can expirement by taking the grills out of the outlets and see if there is still noise that is bothersom.
Good luck in whatever you try.
Jim
