Random orbit
bill Crommett
>I have a random orbital sander by DeWalt that has a sheared off pad. Is there a cement that will re-attach the sponge rubber that has sheared, or will I have to junk it ?
Random orbit
bill Crommett
Re: Random orbit
>Good luck. I tried a number of things on my sander. The best was Shoe Goo but it still didn't work perfectly. It's important to get all the fine sawdust off before gluing.
Silicone caulk? Rubber cement?
Re: Random orbit
Tom Dunlap
>Shoe Goo has never worked on anything for me.
My favorite glue for things like this is a goopy glue called The Welder. With good surface cleaning and prep I've repaired many things.
When I can't find The Welder I buy a tube of marine adhesive from the rack at the Borg.
Surface prep is key. Finding a solvent that dissolves any crud. Next, I spread the glue, push the surfaces together to make sure that both are covered. Then I open the two and let them get fingerprint tacky. Put the two together and tape, tie or clamp both parts.
Re: Random orbit
>Not sure exactly what you are gluing to what. I have small foam rubber mandrels that have hook and loop on them and I use them in a drill to sand turnings on the lathe. If I get too heavy handed I tear the foam rubber. I have glues a bunch of them with CA Glue and most ave worked well.
You might google This To That, a site about what to use to glue what.
Re: Random orbit
JerryBurns
>try Rockler they might have a replacement pad. I found one for my Porter Cable after I bought a new sander so now I have two ROS
Re: Random orbit
bill Crommett
>Thank you gentlemen. I now have several choices to try. I will loook for some of the stick y stuff, but I will be sure to blow things off real clean.
Just buy the part is another option
Ken Garlock, Collin County Texas
>Bill, go to the DeWalt website and look up your sander model. Find the parts explosion drawing, and buy a couple thingamajigs to have on hand.
Often, replacement is better than quick-fix repair,
Ken
Something like this?...
John in NM
>http://www.amazon.com/DEWALT-DW4388-Random-Sander-Medium/dp/B00004RH80
See 'em in Home Despot all the time too....
Found the last stick on hook pad for my Ryobi in the state of NM I think. Wasn't even in their system - but paying $3 for two sure beat buying the whole thing (1) for $15. Why don't they put the hooks on the paper and the loops on the pad?
Re: Random orbit *LINK*
Alexander Grigoriev
>Check the link for DeWalt sander parts
Ereplacementparts
