Jointing with a router
Tom Dunlap
>Now that I have a shop setup to work in I can start on a project that I've wanted to make for a number of years.
The lumber came from a tree that I was paid to remove. Now I'm getting the 'oink out of the pig' by making something useful from the tree. The scraps will end up in my wood stove to get the last bit of oink.
In my lumber stack there are some 6/4 quarter sawn green ash planks. I had them milled with a wany edge to preserve the character of the tree. The first project will be a headboard.
The inside edges of the boards are angled because of the quarter sawn. My plan is to use my circle saw and edge guide to rough cut the edges. After the edges are squared up I'll need to joint them for a good glue up. Wrestling these big boards on top of my 6x48" jointer is not an appealing idea.
Years ago I read an article in FWW on edge joining with the router. In the article they showed how to setup adjoining pieces. The boards are clamped a little closer than the diameter of the bit so that a little wood is taken off both pieces in one pass. The base of the router rode on both pieces so any 'errors' are mirrored and would still glue up tight.
Would I be better off using a flush trim bit and a guide on the underside? This seems like a good idea because the end of the bit will be guided and not be deflected.
Does anyone have experience with a setup like this or suggestions?
The router I have is a Stanley Model 90150M with a 9 amp motor. Is this strong enough to do the job?
What style/manufacturer bit is recommended? Straight...spiral???
