hw floors
kaleb
>Where can i get hard wood floors for a reasonable price? We have a 350 sq room we want to do.. as well as other projects
hw floors
kaleb
Re: hw floors
John E in SC
>Your question leaves lots of questions. How do you define "reasonable"? Assuming you're a DIY'er, what I would do (and have done), is first start with a couple local flooring dealers. There are almost certainly some where you live. Have them give you a "turn-key" estimate for them doing everything. Then you have something to compare against. Then ask them how much it would cost to buy the flooring yourself (finished or unfinished, your choice). HW flooring is fairly straightforward to install if you have basic tools. What I did was buy a pneumatic flooring nailer, used it on a couple of projects, then sold in on e-bay for about $50 less than I paid for it. Cheaper than renting, and I got to use it at my leisure. Now, finishing hw flooring (sanding, applying stain and/or protective coat) can be fairly complicated. I did my own using materials from a wholesale flooring supply house, and it turned out fine. What a lot of folks do is do the labor of putting down the floor themselves, then hiring a professional to finish it. I would say that's probably worth it if you have any doubts about your finishing products or techniques (some flooring finishes are only sold to professional installers - it took a good bit of research and a long drive to find what I thought was an acceptable flooring finish that I could obtain and apply myself.)
If I recall, I ended up saving about $3 a square foot by doing it ALL myself, but it was a fair amount of work. You could do prefinished hw or laminate much easier, but may be a touch more expensive, depending on brand and a ton of other factors.
You can also check your local Lowe's, Home Depot, and Lumber Liquidiators has a good many stores across the country, and will ship flooring to you.
Good luck w/ your project,
John
Re: hw floors
Ray SW Ohio
>Lumber Liquidiators is a good place to start. I did my whole house in prefinished hardwood. The finish will last longer than if I did it myself. I used Bruce hardwood flooring. Has a 15 yr warranty on the finish. Got mine at an outlet store for $1.00 - 1.25/ft. It was a deal I couldn't resist. It was either new carpeting or hardwood. The hardwood was less expensive. I did buy a pneumatic floor nailer. Doing the whole house took time, cheaper buying one than renting one. Sold it for the same price I paid for it (I got a good deal on the nailer too). My 2�.
Re: hw floors
Frank Mutchler
>I've put down hw floors in 3 different homes. Once got a great deal on pre-finished 3/4" oak flooring from the classifieds section of the local paper and twice purchased unfinished red oak from the orange big box.
Pre-finished was quick & easy and the other was a lot of work but fun! It helps a lot if SWMBO is good natured and can live with some clutter;>)
Re: hw floors
brandon mclean
>Thank you for your post.. Very insightful and helped me alot..
Brandon
Re: hw floors
brandon mclean
>Im looking for hw floors as well and posted a message similar to this.. REsponded to the wrong one though.. LOL.. But thanks Im glad I found this post.
Brandon
Re: hw floors
Kaleb Jones
>Thanks for the advice.. Ive heard lumber liquidaotrs is really good place to buy hardwood floors as well
