The Great Flood of '09 (not quite OT)
Gary Evans Tallassee, TN
>Hi all,
Here in East TN since the beginning of Dec, we've received close to a quarter of the percipitation that we normally get in a years time. The accompanying photos show the results, at least in the basement of the store building here in Tallassee.
We've had some water in there before since we sit in a bowl with some extensive hills draining down behind us, but never had this much water this early in the year. I've been pumping water whenever I've had time over the past 2 weeks and figure I've pumped out a little over 100,000 gallons total. At it's high point the water was 30" deep in the shallow end. Hopefully you can see the high water mark on the 4' flourescent light in the pic.
The good news is that I now have a good number for the size of sump pump necessary to handle the maximum flow the next time this happens.
Gary
Re: The Great Flood of '09 (not quite OT)
>Pic 2.
Here's the not quite OT part. I had stacked my thick maple cants down there a year or so ago because of the high humidity. No checking so far.
I was impressed that the stack stayed together and floated off the supports in one piece.
Gary
Re: Pic 3
>Here is what 150 gallons per minute looks like coming through a 2" hose.
Gary
Re: Pic 3
>Bummer, Gary. Too bad you can't save that water for the garden this summer. But I guess right next to the river you can always get water easily. Last summer I hauled water from the river in a 325 gal tank with my truck - at least a dozen trips about 6 miles each.
Brandon Mclean
>wow, hope it lets up soon for you guys.. we are basically in drought conditions here in Texas.
Thanks
Brandon
Got Sawdust?
>Gary, you probably want to get your propane tank out of the water too.. lest it floats away to somewhere dangerous... and then pow!
Dale Lenz
Dale Lenz
>Sorry for your misfortune. Made to sick to see that, it's heart breaking for sure. Good luck
Re: Pic 3
>Thanks, John.
One of the plans for this summer is to set up a good-sized tank on the shelf above our garden and feed it from the creek above. No more hauling water for this guy!
Gary
>Bring a tanker, Brandon. I'll fill you up. Picked up another 5" yesterday and pumped it out overnight last night.
Gary
>Actually it's not propane, it's Freon. Most everything that was floating in the pics is now up on shelves. The pics are a couple weeks old at this point. The flow is down to less than 1/4" per hour at this point so I just go turn the pumps on once a day.
Gary
>Thanks Dale,
It is for sure a PITA, but not heartbreaking. I think that Beth was beginning to suspect the presence of another woman with all the time I was spending at the store. I finally convinced her that I was merely getting to know a 9000 gph water pump.
The wood will eventually dry and before too long I'll have a sump pump in there that will handle the flow so that this shouldn't happen again even if we do get another 12" of rain in a month.
I may have to pull down and clean the electric motors on my air compressor and dust collector, but everything still turns freely.
Gary
