MicroFiber cloth for a tack cloth
Dale Lenz
Dale Lenz
>Friend of mine when to a demo of Kelly Mehler and was sold on using a MicroFiber cloth for a tack cloth. Any experience out here about the MicroFiber rag?
TIA
Re: MicroFiber cloth for a tack cloth
>Yes. I bought one a while back. I though it was kind of pricy, but I figured what the heck.
Anyway - my experience has been it is very good at picking up sawdust and sanding dust. I typically "rough" clean it by putting it down the hose of my shop vac (while on). I have also used it to clean up after sanding well cured finishes. I use the old fashioned type of tack cloth for the not so well cured finishes.
My $0.02. YMMV.
Charlie Self
>I use these with camera lenses more than anything else these days, and to clean LCD monitors. They are excellent for both jobs. I also use one for cleaning my scanner screen.
Advantages on wood surfaces: they pick it ALL up; no chemicals to harm finishes; available in rough or smooth finishes; they never dry out and are easily washable; low cost IF you select from the cloths available at WalMart Advance Auto and similar places. Buy from those with "specialized" microfiber cloths, and you'll get stung. I got three packs of four fairly large (12-1/2 x 14) super smooth cloths from WalMart a couple years ago, for $4.95 a pack, four cloths per pack. I got rougher cloths at the same place for about the same price. WalMart (of course) quit carrying the smooth ones shortly afterwards. I haven't looked elsewhere, because I've got nearly a lifetime supply. Advance, AutoZone, any auto parts place, possibly big box stores might have them.
Negatives: they can be stinkers to wash, especially those with a nubby surface (I've tossed half a dozen of those that picked up too much sawdust and chips to wash out); they lose their attraction qualities IF you use fabric softener. Microfiber dust cloths use static electricity to hold the dust they pick up. Fabric softener is designed to remove "static cling," thus killing their utility to woodworkers (and most of the rest of us).
Microfiber cloth, cheap at auto parts stores
Scott in Montana
>I've used microfiber cloth as a tack rag for a few years now but it wasn't until a neighbor pointed out to me that he used them when dusting his cars that I knew auto parts stores were big on them too. And CHEAP! I recently bought an eight pack of 18" x 24" (probably the metric equivalent)on sale there for $4.99. I've washed a couple of them several times in the washer and they seem to be holding up just fine.
Scott in Montana
Alexander Grigoriev
>One negative thing about them is that they can leave colored fibers on wood, if it's splintery. You want to wipe with the grain to avoid that.
Dale Lenz
Re: Thanks for the responses so far
Dale Lenz
>One of the poster said something about a smooth texture cloth vs. a rough. So which texture for what? Plan on using one just prior to finishing, like a tack cloth.
Thanks again
Charlie Self
>Neither texture is particularly rough, but one has a sligthly less smooth surface, sort of nubby. I use the smooth surface for wipe-down between coats and to get off the final dust. Use the rougher (usually cheaper) surfaces to clean up sanding dust and whatnot before the first coat of finish.
If it warms up a tad tomorrow, I'll try to shoot a photo of the two side-by-side, which may help. It's been too cold to go heat the area with my studio flash units...20 or so bucks to bring it to maybe 50 just is out of my class these days.
Dale Lenz
Re: Thanks, Charlie...
Dale Lenz
>They are cheap enough, maybe I'll try both types. Hope it warms up for you.
Charlie Self
>I just got back from buying propane for the shop heater. That whimpering noise you hear is my wallet.
It's feeling icy now, with a light breeze, but I think tempsa re more moderate (actually, by far) now, and may be more so by mid-week. I hope. I have a couple of table saws to assemble.
