Plywood and rail/ style question (long)
Grant in Iowa
>Hello all,
I am about to glue up two queen sized headboards made as follows:
Legs are 8/4 stock mortised to receive tenons of the rails. A center stile runs vertically between top and bottom rails to add strength and to add character. Both legs and rails are slotted 1/2" deep to receive 1/2" plywood panels. The plywood panels are 1/2" oak veneered cabinet grade plywood. The panels are roughly 28" wide and 24" high.
Now the question:
I know that plywood is said to be stable and excellent for panels for that reason. I'd like to glue them into the slots as I assemble the headboards, but thought I'd ask for advice first. I'd like to avoid having loose panels, and panels that move and might catch a sleepers hair for example. But I will do what is necessary to accomodate wood movement.
As a minimum I will be planning to glue the center of the panels to the rails and thought of putting a spot of silicone at various places around the perimeter to allow movement, but mostly keep the panels stable. Also, how much, if any expansion room should I allow around the edges of the plywood?
Thoughts and suggestions would be appreciated. I usually build solid wood projects, so this new fangled plywood has me wondering what is the best approach.
Thanks in advance,
Grant in Iowa
Re: Plywood and rail/ style question (long)
Bill Hylton
>As a practical matter, plywood is stable. The legs, rails, and intermediate stile form a frame. Frame members typically are narrow enough that cross-grain expansion and contraction is negligible. You don't really have wood movement issues in this construction.
Glue away!
Bill
I agree
Chris Knob
>Make it so. Glue it up and it will be as stable and solid a a slab of slate!
Re: I agree
Glenn Madsen near San Francisco
>I built an oak headboard in the manner described some 5 or 6 years ago. It's solid and stable still.
Now, if I were to build it again, I would pay closer attention to the graphics of the grain pattern. There's always something to learn. Piled up with pillows, as LOML has it, it's not a big deal.
Re: I agree
Brianna
>Where is good place to find hardwood floors online? or better to go to home depot or somewhere?
