Have a question? Ask Woody!
OT - Naval history
OT - Naval history
OT - Naval history
Tom Pilsbury (Chicago)
>It was necessary to keep a good supply of cannon balls near the
cannon on old war ships. But how to prevent them from rolling about the
deck was the problem. The best storage method devised was to stack them
as a square based pyramid, with one ball on top, resting on four, resting
on nine, which rested on sixteen.
Thus, a supply of 30 cannon balls could be stacked in a small area
right next to the cannon. There was only one problem -- how to
prevent the bottom layer from sliding/rolling from under the others.
The solution was a metal plate with 16 round indentations, called,
for reasons unknown, a Monkey. But if this plate were made of iron,
the iron balls would quickly rust to it. The solution to the rusting
problem was to make them of brass - hence, Brass Monkeys.
Few landlubbers realize that brass contracts much more and much
faster than iron when chilled. Consequently, when the temperature
dropped too far, the brass indentations would shrink so much that the iron
cannon balls would come right off the monkey.
Thus, it was quite literally, cold enough to freeze the balls of a
brass monkey.
And all this time, you thought that was just a vulgar
expression, didn't you?
Hope you're all keeping warm.
~Tom~
Re: OT - Naval history
Paul Londo
>That's a neat story but it's an "urban historical myth". I've done a lot of research on this (in one of my other lives I'm an 18th century french military reenactor ,sgt of artillery) and wanted to make a brass monkey but found out they were never really used especially onboard ships. The cannonballs on ships were stored on shot racks next to the guns or stored in the hold. In the heavy rolling and pitching of the ship the balls would never stay in a pyramid.
Robert R Clough - Thorncraft
>Paul, you are basically correct. However, so called brass monkeys were used on board naval ships - but only in harbor, at anchor or docked, and only for inspection purposes. Otherwise, yes, the cannon balls would indeed roll off.
However, the term does come from that and was somewhat vulgar then.
There are so many devices and traditions, both naval and military that became more important in peacetime. They become a "meaning" in and of themselves and are kept because they"should be". I don't know about the current army, but back in 1951 we still did close order drill and the manual of arms. Both of these had a purpose up to and perhaps a bit beyond the 1860s but cetainly not in 1951. I rather enjoyed both but I thought of the exercises as a form of dance.
Charlie Self
>Maybe. I went through Parris Island in 1958 (devil of a way to spend winter into spring, a dozen weeks of hell), during which time it was explained to us that originally close order drill was designed to ease the movements of large bodies of troops. Close order drill allows one person to move a slew of pipple, without colliding with other moving slews of pipple. It's still useful, though less so in these days of wheeled and rotored transport, I'd guess.
For the ultimate in drill precision, see if you can get a tape or DVD of the Marine Corps Silent Drill Team. We used to try to imitate these guys, against orders. You'll see why for both if you watch.
